Should I do this to my Tundra?
bennysmall
instigator of fun
Hi everybody,
I've been going back and forth about installing lights like these on my '02 Tundra.
A recent trip through the desert proved my current stock lights just aren't cutting it. I couldn't see as far ahead as I would have liked, nor could I see far enough to the sides of the road to spot critters such as deer before they were almost in the road. I do need to resurface my headlights (I've heard toothpaste works for that?) but I feel I want even more light ahead of me and to the sides for night driving when I'm way out there. It seems like a set up like this would also allow me to swivel the lights to allow for a wider field of view, as well as illuminate the terrain further in front of me than my stock high beams.
Basically I'm wondering if there are any obvious drawbacks to a set up like this?
Does it look totally lame?
Is there any way to just beef up the output of my stock headlights (high beams) and/or expand the width of their illumination?
Any advice is much appreciated!
Auxiliary lights are nice, but some patterns are not going to give you your desired side coverage. I found a good HID kit (H4 IPF 55/65w 100/110w equiv. on '00 XJ) outperformed my 55w aux lights BY FAR. After install, the aux lights were only noticeable beyond (estimated) 300+yds. I would still use the aux lights on open terrain, but the HID was a very practical upgrade.
Proper installation and tuning of these items is critical to their effectiveness.
Hope that helps.
Mafo
Expedition Wannabe
Toothpaste or TCut are good products for cleaning yellowing headlamps, although neither are that much of a permanent fix. Here's a great video on how to do it best
http://youtu.be/iRl8hGhKth8
wreckdiver1321
Overlander
I have 2 Hella 4000s. One in a driving beam, one in a spread beam. Gives me two light patterns: a relatively narrow beam that gives me a lot more than my headlight range, and a wide beam that throws light about 100 yards wide. Excellent amount of light and I don't worry at all about spotting deer or other critters.
Derek24
If you're going to put two holes in the bumper I'd suggest an LED light bar. Throws more light, less power, and easier to hook up. A 22 inch light bar would do fine and look great on the front, also they are about $80 on amazon.
dyogim
That's a pic of my truck when it had IFS.
There's definitely a lot more options for lights that will provide more light output for your needs. Later, I converted those Hella 500's to use HID's. However, I was still not happy with the results. Definitely look into LED's. As far as the mounting location, I never had any "bounce" issues with the lights mounted there and would've kept them there if it wasn't for the accident. Another option is to mount them in the grill.
bennysmall
instigator of fun
dyogim, that's wild! This was one of the first photos that came up when I googled "first gen tundra off road lights." Thanks for the advice! I'm definitely looking into LEDs. Thinking the Baja Designs S2 pros could work well. Derek, I do like the light bar idea but can't find a light bar with the same output and versatility as the S2 pros for a better price. Any suggestions?
Thanks again!
Dances with Wolves
aka jk240sx
Does anyone make a front bumper light bar for the 1st gen tundra? I am getting a N-fab for my Tacoma when I get to the point of front lights. From OP's picture, I would think that the lights would be jiggly mounted like that.
Mrknowitall
OP- what year/bumper is your truck? My 03 had the plastic facia, and there's little or nothing worth bolting lights to.
I had a set of Bosch Rally 225 drivers mounted to the grille- always had bounce. I did have stabilizers, but those suckers are heavy. LED light bard have several huge advantages-
1- they're easy to clear, since the grille swings up.
2- since they're vertically compact, they have very little moment if inertia, meaning they should be more steady, even with less than perfect mounting options.
3- Energy efficient. 100W of LED is a ton of light.
The divergence is on cost- the simple, small reflector lights can be had (on amazon) for less than $200. These will throw a ton of light down the road, but also have lots of scatter.
The nicer name-brand lights are better at getting light down the road, in a useful pattern, but you'll pay for it.
I'll probably order a "generic" single row curved light bar for the Foz soon. Hoping the curving will help with the light cast.
dyogim
I never had any "jiggly" issues with those mounted to the bumper. Even when I was offroading. Prior to those 500's I had Procomp 6" halogens. Even those didn't jiggle.
bennysmall
instigator of fun
Thanks all for the advice!
Mrknowitall, I've read some stuff from dyogim about mounting 500 style lights on the bumper like that. In fact the original photo I posted happened to be of his rig! My Tundra is an '02 limited, I have a bit of plastic on the top of the bumper, but underneath is metal. I've definitely been researching light bars, but after Bj's post I'm thinking Baja Designs Squadron Pros are a good way to go as well. I like the look of the S2's better, and I know you get what you pay for, but... I just graduated college! (read: more broke than I was IN college!). Ah... light bar, squadrons, S2s, Hella 500s... Choices choices choices. Cost IS a BIG issue for me though. So we'll se where it goes!
PNWav
