Water tank Level Gauge
coronan
Hello,
I"m looking for a solution for monitoring the level in my water tank on a custom camper van. The water tank is going to be mounted under the van taking the place of the spare tire. I have room for 6 to 12 gallons with out impeding clearance.
Being under the rig the sight glass is not an option. (although I love the simplicity)
A dip stick is not practical because gear will be stored on the floor above the tank.
SeeLevel is too much $$$
I'd like to come up with a sub $100 solution.
McMasterCarr.com sells float level switches. Part # 50195K93 $13 ea
What have others come up with????
Thanks!
doug720
A simple water level - Like a real water level.
Connect a piece of clear hose to barb on the lowest part of the tank. Run the shortest piece of hose possible to a point you can hold it(or mount it?) so the end is at least the level with the top of the tank. Install a threaded cap on the end.
To read the tank water level, open the cap and you have a water level. Mark the hose with full, 3/4, 1/2 and 1/4 levels.
Just a simple method that always works and maybe cost $10.
LeishaShannon
We use something similar to this - http://www.ebay.com.au/itm/G1-Flow-...11?pt=LH_DefaultDomain_15&hash=item1e82b039df these are easy to install (no messing with the tank) and extremely accurate , ours shows tank capacity down to 100mls.
We made our own using a $5 sensor (http://www.ebay.com.au/itm/DC-5-18-...33?pt=LH_DefaultDomain_15&hash=item1c35b6ea29 ) and a $25 "arduino" microprocessor that displays the remaining tank capacity and current flow rate on our iPhones. I can post the arduino code if this is of interest.
T3kNomad
arduino code post
Yes, if you please, post the code. This solution looks promising!
Henrybrowne
