Evan's F250 CCSB build
mtm_motors
I'm starting a thread to document my cousin Evan's build on his Powerstroke 5 spd F250. He had been looking for a late model OBS for quite a while and finally found a suitable one a few months ago.
Our grandparents had a 95 F150 Eddie Bauer 4.9 5 spd that we both learned how to drive manual in around the farm. He has a similar truck now, but of course everything is better the heavier duty it is! Hence the search for a late model CC Powerstroke. Interestingly, all of these trucks have been the same color.
I'll post what he has done so far and then post updates as he sends them to me (I'm not close to the build, unfortunately).
The truck as he bought it:
Axle removal for SAS. He planned on doing it if he wound up with a F250 and found a donor axle from a F350 within a few weeks of buying the truck.
Time to try out some Hummer tires...
A little tight
Nice difference in ground clearance!
Time to prep for some body repair and paint
Laying some filler
New tailgate
mtm_motors
Factory running lights added
Primetime
Color!
Hauling her home behind the mighty F150
Making a new grille
Gotta make some room for those 37s...
He found a set (the others were loaners) on 12 bolt re-centered beadlocks. Looking pretty beastly. This is with no lift, I think he plans to possibly do a shackle flip and that is it.
Gotta put something on that new grille
A little Cardboard-Aided-Design (sorry, whoever I stole that from)
I recommended cutting the flares flush with the top and extending the bumper under them, I think he may wind up doing that
Grille coming along
And that brings us to its current status. That was stretched out over the past few months and I have forgotten some of the details but I will keep this thread up to date as his build progresses
mtm_motors
A few small trim details to update.
And... it is an F250 again!
He had some issues with clogging fuel filters and then shutting down before, so I believe that will be addressed next. The PO had run it on veg oil so it should be pretty simple
mtm_motors
He got the fuel pickup pulled and it came out in pieces... replacing that should fix some issues!
With the new grille you can no longer access the hood release lever, so he made an extended handle.
In this shot you can see how much wider the track will be
mtm_motors
A little more progress.
Brake job on the new front axle
Starting to turn some cardboard into steel plate...
And... since I've had no real contribution to this thread, here's an adventuremobile from where I work :p
Lockwoodjd
