How I calibrated my ARB Fridge
ripperj
I don't normally leave the forum for blogs, but I'm glad I did this time. I didn't know you could tweak the reading in on the ARB, mines a couple years old, hopefully it will work.
Thanks for posting that up
Keith
Sent from my Passport using Tapatalk 2
tarditi
Great writeup! Mine is off by 10 degrees and I put a cooler thermometer inside to confirm... now I can just calibrate it!
TimS
Thanks for the info. What is the display mode that comes up when the fridge is put into calibration mode? Mine started with A-6F
I just want to make sure its right.
Thanks
TwinStick
This is GREAT info !!! I just picked up a 50qt & a 82 qt. Mine are off by about 10* as well. Thanks for this.
wanderingjeep
Paramedic
Thanks
A-6F means you are already set down 6 degrees from default of A0F. Run the test I describe and find your calibration. You may be right on or you may need to adjust.
TwinStick
Does this re calibration stay in the memory even after it is turned off & unplugged ??? Or does it have to be done every time it is plugged back in ???
TwinStick
So, after raising my 82 qt by 6* in re calibration mode, this morning, the outside temp reading on cooler is fluctuating between dead on & 1* different, from the inside temp !!! Awesome.
TwinStick
Petersmithinak
