Blackdawg
Dr. Frankenstein
Nice air blackdawg......that's SoCal desert action right there![]()
Thanks man
Always enjoy your pics Monte. Looks like that LT is getting some good use! :smiley_drive:
Thanks man!
Im definitely abusing itcan't wait to redo the rear setup a bit! and add a lot of gussets for peace of mind
What are your plans for the rear? Spring under axle? Bumps? The suspense is killing me! :coffeedrink:
T100 axle swap would be super easy considering you have an 8.4" in the rear already! Just plug and play the 3rd.Well for a temp thing i am going to put a t100 axle back there then put 12'' or 14'' ADS shock outside the frame on custom hoop mounts that will barely go into the bed so i'll still have my bed.
I put on Wheelers Super bumps just before this trip and man am i glad i did. Super nice. But hydros will replace those.
Then....save save save save save
for a 4 link rear, internal cage, engine cage and motor swap to a 2jz.
Be expensive...but should be fun![]()
	Off topic but have you ever tried the stimulator version of the royal wulf? One of my go to flies for brookies here. I tie 12-16 inches of 5x tippet off the back of the fly and add a nymph...deadly any time of year or day.
2jz huh?? That would be insanely awesome! But an insane amount of work. The truck would be sitting for a while I'd imagine. Ever thought about boosting the 5VZ with a turbo? A properly sized turbo and necessary fuel upgrades would net you some impressive power numbers. Even with the factory ECU and a piggyback. Or run standalone.
Lots of turbo builds out there, we've seen em all. I like this one:
http://www.samsonfab.com/phpbb2/viewtopic.php?t=34
