Been researching the feasibility and utility of off the grid AC use for campers with large lithium banks and large solar arrays (the holy grail!). Our current set up is 400am LiFePO4 Victron Batteries, and around 1k watts of solar. We are considering adding an additional 200ah of battery.
Options I have found thus far. Please double check my math and efficiency ratings, I am a novice to camper electricity.
Indel Sleeping Well Arctic Plus
http://www.indelb.com/products/truck_air_conditioning/sleeping_well/sw_arctic_plus
http://www.driveproducts.com/wp-content/uploads/2014/04/Anti-Idling-Brochure-0913_web.pdf
(Page 16)
Split type system. 12 volt native
BTUs - 6150
Watts 744 or 660 (depending on which source you read)
Efficiency 8.26 or 9.31
Pricing?
Arctic Breeze
http://www.arcticbreeze-truckac.com/content/arcticbreezeintro.html#specs
12 volt system
BTU 8000
Watts 600
Efficiency 13.33
Have read that their is some question surrounding the artic breeze efficiency numbers. I have also read it is possible to separate the components out and install as a split system (apparently this has been done in a sprinter).
This article seemed to indicate it struggled to keep an entire truck and sleeper rig cool when the outside temps topped 100. I am guessing a camper would be much better insulated, but it bears consideration.
http://www.truck-drivers-money-saving-tips.com/arctic-breeze.html
Indel Sleep Well Oblo Twin
http://www.indelb.com/products/truck_air_conditioning/sleeping_well/sw_oblo_twin
Single unit roof mount style. Looks to be 24 V only
BTU 6150
Watts 840 (35 amps on high x 24 volts)
Efficiency 7.32
Dometic Blizzard Turbo
http://dometic3frontend.qbank.se/episerver/4d0b33b5012968d7184664859cf30a80.pdf
Split system. 115V native (requires an inverter, so efficiency ratings for 12v power will have to take into account inverter energy losses). Looks like the condenser unit on the outside runs on 12v and the condenser unit on the camper interior runs on 115v.
BTU 7000
Watts 816.5
Efficiency 8.57
Coleman Mach 8 Polar Cub
http://www.campingworld.com/shopping/item/polar-cub-9-200-btu-coleman-mach-air-conditioner/49864d
Roof mounted
115 V native (efficiency has to be adjusted for 12v power due to inverter losses)
BTU 9200
Watts (11.5x115) 1322
Efficiency 6.95
Dometic Penguin
http://www.dometic.com/USA/MS-7207-...n-II-135K-Low-Profile-Rooftop-Air-Conditioner
Roofmounted, 115 native
BTU 13500
Watts 1460.5 (12.7 x 115)
Efficiency 9.2
Indel Cube
http://www.indelb.com/WS/DownloadPdf.aspx?co_id=201&filename=sw_cube.pdf&pdf=y
12 or 24 v. Free standing, requires vent attachment, or out a window
BTU 3200
Watts (36x12) 432
Efficiency 7.4
DCAIRCO
http://www.dcairco.com/product/truc...24-vdc-direct-current-rooftop-air-conditioner
Note - I have emailed several times for a quote and have not heard anything back
BTU 9000/7650 (unclear which is which here)
Watts 720 (continuous duty)
Efficiency Unclear based on BTU, but seems to be greater than 10
230V Options
Mitsubishi Heavy
https://www.mhiaa.com.au/index.php/component/mitsubishi/products/default/96
BTU 6800
Watts 350
Efficiency 19.5
Truma Saphir
http://www.truma.com/int/en/air-conditioning/saphir-compact.php
Under bench mount unit. 230v native
BTU 6150
Watts 660 (it is unclear if this is with losses from their available, model specific inverter)
Efficiency 9.31
Dometic HB 2500
BTU 8500
Watts 897 (3.9 amps x 230 volts - no 12 V data available for their model specific inverter)
Efficiency 9.47
Dometic Freshwell 2000
http://www.jacksonsleisure.com/cara...c-freshwell-2000-under-bench-air-conditioner/
BTU 6100
Watts 650
Efficiency 9.38
Fujitsu 9RLS3
http://www.fujitsugeneral.com/wallmountedRLS3_specs.htm
BTU 9000
Watts 575 (2.3 x 230)
Efficiency 18 (stated) 15.65 (calculated)
Mitshubishi MSZ-FH09NA
http://www.mitsubishipro.com/en/pro...-zone/m-series-heat-pump-systems/msz-fhmuz-fh
BTU 9000
Watts 560
Efficiency 16
(Page 16)
BTUs - 6150
Pricing?
Arctic Breeze
12 volt system
BTU 8000
Watts 600
Efficiency 13.33
BTU 6150
Efficiency 7.32
BTU 7000
Watts 816.5
Efficiency 8.57
Roof mounted
BTU 9200
Efficiency 6.95
Dometic Penguin
BTU 13500
Efficiency 9.2
Indel Cube
BTU 3200
Watts (36x12) 432
Efficiency 7.4
DCAIRCO
230V Options
Mitsubishi Heavy
BTU 6800
Watts 350
Efficiency 19.5
Truma Saphir
BTU 6150
Efficiency 9.31
Dometic HB 2500
BTU 8500
Efficiency 9.47
BTU 6100
Watts 650
Efficiency 9.38
Fujitsu 9RLS3
BTU 9000
BTU 9000
Watts 560
Efficiency 16
