What axle for my m-416?
Do you think it would be wide enough to ruin 35s or would you need spacers? Did you use long spindle or regular? Thanks
I can measure when i get home it should fit. I have 4.5 " of backspacing on my rims. I will measure height for you based on my tire. Might give you a start on how things will fit together.
Sent from my SM-N910P using Tapatalk
Missed your other question. I bought the off road suspension w 4" of lift.
GFA
You'll need the off-road spindles. They are about 1" wider between the wheel and frame vs the standard spindles. This pic is of 285 70 17's on 4.5" back spacing wheels on the off road spindle. There's about 1.5" of clearance to the large bolt in the pic. The other option is spacers but I wouldn't bother if it's avoidable.
steppone
Cool, thanks
