Eric Edwards
So I snagged one of the last two K9 roof racks left in the states from Equipt yesterday. I have to say I am very, very impressed by the quality of this rack. I've owned a Baja Rack and FrontRunner on my Landcruiser 200, and I have to say Eezi Awn has a winner on their hands here. Some thoughts:
Pros:
- rack is aluminum and welded together
- rack is very light, total of 71 pounds including feet
- powder coat is on par with FrontRunner and light years ahead of Baja
- quieter than FrontRunner and a touch bit louder than Baja
- entire assembly is very, very rigid and well built. Feels like fortress
- Eezi awn has some very nice tents and awnings that K9 works seamlessly with
- Completely flat top
- slats run length of roof vs. horizontally
Cons:
- not as many accessories as FrontRunner, though I think many will work on the K9
- about 10-15% more expensive than FrontRunner
The entire assembly on 275/65/18 tires and no lift is 82 inches (about 2 inches shy of 7 feet). These images were taken a couple minutes after the rack went on at my buddies garage... and apparently I had put the wind fairing on backwards. I did try it without the fairing and the noise definitely increased, but nothing like the insane resonance you get if you remove the wind fairing off the FrontRunner, which made the vehicle impossible to tolerate.
Almost forgot, I used Mercedes felt tape on the feet cover to protect the gutter and keep it from rubbing on the four height adjustment bolts on the legs. I got this idea from another member here in PDX who did the same when installing his FrontRunner.
Pros:
Cons:
