The WeldTec Designs "No What-if's" program for vans
Weldtec Designs
In the past few months we have had numerous inquiries wanting to know If our 2 wheel drive suspension components can be used with 4x4 conversions. Of course there are so many variables in these questions for it to be a simple answer...... So we came up with this......
http://www.weldtec-designs.com/blog/
Thanks for looking.
REDOVAL
Awesome, especially for those who can't make up their mind. I'm glad I stuck with 2wd, but it's nice to know there is an "out" if I change my mind.
Scott
Haf-E
How much work would it be to install the transfer case without the front axle in a conversion to allow for a low gear? That, together with a good rear axle locker, your lift and good tires would probably be enough for 90% of expo needs. Does the gas tank need to be modified? Thanks.
Grngiant
The tank must be modified. The front output of the transfer case and the front of the fuel tank share the same space. Tank needs to be shortened.
ert01
That is an awesome offer Weldtec! I have a feeling your components will be popping up on more and more vans here if you guys keep this up!
Grngiant
All you have to do is drive one and you will be sold on its value and performance.
I would be happy to take someone for a ride in my van if they are in the central Vt area and wants to check it out.
Weldtec Designs
Thanks Kevin, I hope some of the folks out east take you up on that.
Lockwoodjd
