TeraFlex Product Highlight: JK Rear Utility Cargo Rack
TeraFlex
The TeraFlex JK rear utility cargo rack provides additional storage options to organize and secure cargo. Taking mounting cues from the Nebo roof rack, the cargo rack also provides universal accessory mounting compatibility. The extruded aluminum rails take advantage of industry standard 10 series T-slot mounting to allow the use of readily available hardware to mount small accessories or recovery equipment.
An optional side panel kit is available separately
Fits Wrangler Unlimited 4-Door models only. ( A 2dr version is in the works)
• Height adjustable to customize for different cargo needs (from cargo floor to bottom of rack on highest setting = 23.625" and on lowest setting = 18.825")
• Sleek low profile aluminum design
• Composite corner assembly support
• Extruded aluminum construction for reduced weight
• UV resistant hard anodizing finish
• T-slot channels on each rail for tie down points & accessory mounting
• 18 ga. stamped steel floor for rigidity and structure
• Floor panels include accessory mounting holes
• Black powder coat floor and side panels to resist abrasion and increase durability
• Load is carried and supported by the factory sport bar
#4820000 $299.99 Natural Aluminum Finish (December 2015)
#4820020 $425.99 Black Finish (January 2016)
https://teraflex.com/shop_items/563ba7c005a25c5bb19c9976
RobFord
I like the price. What shops in the Denver area will have one I can look at?
Any more details on the Side Panel kit?
Does the cargo netting come with the shelf?
IndyRubicon
Globetrotter
I particularly like that it's adjustable. While I'm determined to build my own rack, if I fail miserably, I'll likely be in the market for this.
sunnyaz
