Gen III Montero Wheel Options
ljkup
Hello. What wheel options are there for the Gen IIIs? I haven't seen very many people running anything other than stock wheels. Here is the wheel info for the Montero that I can find:
MITSUBISHI MONTERO 1992-06 Metric: 6 X 139.7
Standard: 6 X 5.5 12 X 1.5 108.0
MITSUBISHI MONTERO 2001 > Metric: 6 X 139.7
Standard: 6 X 5.5 15 X 6 12 X 1.5 67.1
This looks similar to the Toyota FJ specs:
TOYOTA FJ CRUISER 2007-08 Metric: 6 X 139.7
From: http://www.roadkillcustoms.com/hot-...Makes=MITSUBISHI&Models=MONTERO#axzz3skKLrpUI
Eric M
Similar other than the nearly doubled center bore. If you want to use them you'll need hub-centric rings. Also consider the backspacing.
ljkup
To my understanding, the hubs on the gen 3 are 108. Is this correct? If so, the only thing to worry about would be back spacing.
Sent from my SM-G900T using Tapatalk
ljkup
Yes, I do want to get some toyota fj wheels on my Montero. From what I've reaearched, gen 3 wheels have +10 mm offset and fj is -10 mm offset.
So they should work but may limit tire width. I'm only wanting to go 10.5 width anyhow so this should work out.
It may just be a trial and error project. Thanks for the help!
Eric M
No, the Gen 1 and Gen 2 are 108mm. The Gen 3+ is 67.1mm.
ljkup
Thanks for the help clarifying. Maybe a gen 3 what wheel, tire and lift combo thread is necessary.
Styer
I've got a set of 14+ 4Runner SR5 OEM wheels for sale if anyone is interested.
Lug pattern: 6x5.5 or 6x139.7
Backspacing: 4.5
PM me for more details if interested
Sent from my Nexus 4 using Tapatalk
iStan814
