Fender flares
HSL
Will the LR3 fender flares fit on an LR4 (2011)? Prefer the non-painted look
I think they are the same in the rear but the front might be different. If I were you though, I would use plasti-dip matte black on your LR4 flares and it will look awesome. Provides a bit of protection from weather fade and light scratching as well on the trails but not the heavy stuff obviously.
Also, you can plasti-dip with the parts on the car which will save you a ton of time and effort.
You can pick it up (Plasti-dip, or spray on vinyl) at just about every hardware store now and its relatively cheap. About $8-10 a can out here in Hawaii. Then you can do the hood black out as well :wings:
Derel1cte
I think the LR3 parts would fit just fine on the LR4. Especially considering the painted fenders that came on the 2009 LR3 are the same part #s as the LR4 fenders.
The parts you will need are:
DGP000145PCL
DGP000155PCL
DFK000045PCL
DFK000055PCL
DFJ000022PCL
DFJ000032PCL
Sweet!
DGP000145PCL
DGP000155PCL
DFK000045PCL
DFK000055PCL
DFJ000022PCL
DFJ000032PCL
silvajt
I had mine swapped when I purchased my 2014 HSE. Here are the part numbers I used, which were mentioned above, plus the ones ending in 124 and 134.
DFJ000022PCL
DFJ000032PCL
DFK000045PCL
DFK000055PCL
DGP000145PCL
DGP000155PCL
DGP000124PCL
DGP000134PCL
Photo shows what it looks like now.
silvajt
You are correct. I forgot that we had dropped those last two since they were identical to what was already on the doors and only used the six that you previously mentioned.
DanoWall
