20" wheels for a Range Rover Supercharged?
3240
So the stock air bags are capable of six inches of lift from the factory? Does the cross link air suspension function in terms of down travel? I am not trying to argue, but I'm completely confused . I heard directly from LR that the bags didn't allow for this much lift so I'm anxiously awaiting pics and detailed info.
No. The airbags are still at stock levels.
jymmiejamz
Well, if you have to ask....
Actually, the point is all about ground clearance. Late model IFS/IRS Rovers have pretty good clearance stock, but if you really want to push things you'll run out of break-over in a hurry.
I fully understand the point that fitting larger tires will give you better ground clearance, but if you plan on 'pushing things' you are going to have more problems. Its like taking one step forward and two steps backwards. I imagine the suspension travel will be very poor as it is likely already close to being topped out at this height.
zelatore
Well, we'll have to wait and see exactly what was done. If they simply maxed out the stock components with something like a huge rod lift then you would be right. But from what the OP is telling us, and I'm willing to take him at his word until I have a reason not to, it sounds like quite a bit more was done.
Again, we can only wait to see exactly how it was done.
3240
Nothing is even close to being topped out. I promise I'll post some better pictures and details soon. The individual who made this lift is well known for his H1 lifts. I want to get his OK before posting any details.
Eniam17
If this ends up being as robust and well engineered as it sounds, it would be a huge step forward for modifying new rovers. We all know how difficult it has been trying to deal with anything more than the maximum airbag limits and 33" tires on the lr3/4 and previous full size / sport range rovers. is it possible the new models Came from the factory in such a form that they are easier to lift and fit 35+ tires? Will this modification the OP is doing result in any more off road capability, or will it end up being essentially a very expensive "body" style lift? Very excited to learn more and see what this is all about . Either way, very happy to see people working on the new model rovers.
3240
The whole purpose of this modification is to increase off-road performance. I push my trucks about as far as I can for my skill level. Can't wait to test this out when it's done.
These are some pictures of my G and Sport. Both have a small lift (there's not much available) with slightly larger than stock tires.
TexasTJ
Climbing Nerd
From the rear shot it looks like he droped the hole rear suspension. Some sort of IFRS drop bracket?
zelatore
Which shot? The suspension pics above are his G I think.
Though I like the way you're thinking. It might be possible to design some sort of drop brackets to lower the pick-up points on an IF/RS Rover. Of course that would require longer half shafts too as well as any number of other things I'm sure. But it's an idea.
TexasTJ
Climbing Nerd
The rear of the lifted 2015 Rover Sport
zelatore
There's got to be more than just spacers. Plus he might be counting tire cost in the price. Ever price 5 new 37" MTRs?
I know it's tough, but we really should wait to hear more from the OP. We're just speculating until then.
3240
Tires aren't included in the price. I'll ask if I can post details tomorrow. Hate to keep you all hangin.
Hope to find time to head to Moab after the Holiday's and see what this rig will do.
off_to
