Nice fatbike! It's crazy how many manufactures are getting in the game now.
[You can always build up and swap in a set of 29+ wheels to go hit the XC trails.
I do agree that Cannondale is late to the game but maybe they waited for a reason. I've been on quite a few other brands and this one just seems dialed on the geo. I'm by no means a full on fat biker but when the Dirt is covered, I gotta say, they are super fun. You can always build up and swap in a set of 29+ wheels to go hit the XC trails.
Absolutely. However, technology trickle-down is beginning to put some lightness into many of the components that contributed to the fatbike's portly reputation. Take tires, for instance. My old Surly Nates weighed in at a staggering 1580 grams each, +/-. My current Panaracer Fat B Nimbles (see photo above)...1135 front, 1147 back (weighed both prior to mounting). That's nearly a pound of rotating mass at each wheel. I got them on Amazon for $59/each. The effect it has on handling and responsiveness is galactic, to put it mildly. My point here is that perhaps just a new set of lighter tires may do the trick. Why lay out $500-$1000 for a set of 27.5+s or 29+s if modifications on what you have work?
Caveat is that the FBN's measure narrower than Nates (I believe). That may have also played a factor in the handling/responsiveness as you're now on a "smaller" wheel. But as you said, tires (and wheels) make a big difference, for sure.
The lefty fork design is really unique and that goes way beyond the funky aesthetic. Odd as is sounds, it is extremely stiff, torsionally (twisting). That helps immensely with steering accuracy. The internals of the fork are squared. That reduces much of the twisting flex that all manufacturers try to mitigate with heavy crowns and bridges. Also, whereas all forks have two cylindrical components sliding against each other with bushings, the Lefty (squared on the inside) uses four internal planes (sides) of roller pin bearings. Lots of them. 88 as I recall. So, the fluidity of the suspension action is stellar. That eliminates almost 100% of the "sticktion" that effects normal forks. So, a Lefty is stiffer, smoother.What is the benefit to the non-traditional fork/lefty as opposed to the standard fork?
Do you have any feedback on how the Olaf Lefty compares to the RS Bluto (if you ever had a chance to ride one)? I am finishing up my 27.5+ Lefty-equipped Bucksaw, but standard Lefty forks won't handle 4" tires.
