2003 Montero Odo issues
ljkup
I am looking for a GEN III Montero but am a little concerned with some that I've found. Is there a know issue with Odometers not working or being inaccurate?
vanroth
Yes there were a large number of Gen III's that had bad clusters that affected the temp gauge (and possibly the fuel gauge). The typical fix was replacing the whole cluster, which reset the Odo, but it can be fixed by reflowing some traces on the cluster ECM.
I recommend any Gen III Montero buyer to get a carfax and personally I would be skeptical of any low mileage examples.
Toasty
Maybe that's why the low milage ones I found were so rough.
ljkup
That makes sense. I've read about the temp guage issues, just wasn't sure if that affected the odo. I found another that was suspicious. Talked to the dealer. Said there weren't any records and was sending me autocheck and carfax. 2003 with 19k miles.
Sent from my SM-G900T using Tapatalk
Sabre
Overlanding Nurse
Yeah, it's not that the odo was affected, but that the whole gauge cluster was replaced on some.
newworld2004
so , just to make sure low millage ones in fact is low millage Montero will relaying on Carfax will be enough? found 05 with 42K miles on it, Carfax shows accurate miles.
vanroth
You should be good as long as the Carfax "story" make sense. If you can take a look at the truck, it should be in pristine condition with such few miles. Little things that are worn are a dead give away (like dash bulbs burned out, excessive seat wear).
I doubt it will show anything different, but you can use Ebay's AutoCheck as well (there is a trick to get it for free).
Low mileage trucks are out there as I just picked up my '06 with 56k on the odo. There was a black and tan one in NC with ~40k that I missed by one day a couple of months ago.
Good luck and great catch!
newworld2004
Thx, what is good /fair price for 05 with 42k on it. ?
PNWav
