Interested in a Hummer H3T
RedF
Another alpha/adventure T Owner here. Love mine, but you'll want to plan on some upgrades as soon as you get one.
Steering rack bushing kit, motor mount bushings, and shocks when you level it. Your looking at about $1,000 in parts to solve the common problems with these.
Sent from my SM-G900V using Tapatalk
What's the problem with the motor mounts?
Sorry, axle mounts, not motor mounts.
The front axle is a crappy three piece design bolted to the frame using even crappier rubber bushings. The whole thing is easily the worse part of the truck, but replacement poly bushings at least help stiffen it up.
RedF
Check out outfitter designs for replacement mounts / bushings
Ah, that makes more sense. I read a bit about that problem.
Lockwoodjd
