New - Toyota 9.5" 4.88 Gears
nitro-gear
Supporting Sponsor - Differential & Axle Parts
Nitro's new Toyota 9.5" rear 4.88 ratio gear supersede part number TLC100-488-NG. The previous TLC100 gears had a 29 spline pinion, our T9.5 gears are 32 spline. Older models can now upgrade to these gears with our conversion yoke YOKT60060 and Master Install Kit MKT9.5, for a pinion spline upgrade.
Vehicle Applications:
**1998-2007 models will require yoke YOKT60060 and Install Kit MKT9.5**
Rear Diff:
1998-2007 Land Cruiser 100 Series, HDJ100, HZJ105, FZJ100, FZJ105, UZJ100
1998-2007 Land Cruiser Burbuja & Autana (Venezuela)
1998-2007 Land Cruiser 70 Series
(matching front gear T8R-488R-NG)
2008 & Newer Land Cruiser 70 Series
2007-2014 Tundra w/ 4.6L 1UR-FE or 4.7 2UZ-FE
2008 & Newer Land Cruiser 200 Series, GRJ200 URJ200 VDJ200
(matching front gear T9R-488-NG
Also available in complete 4x4 Gear Package Kits with front and rear ring & pinions and front & rear master install kits:
Features:
  • 2 Year Warranty*
  • 32 spline pinion upgrade for 1998-2007 models
  • 8620 gear forging
  • Precision machined
  • Triple lapped
  • Rockwell hardness tested
Tech Note:
32 spline pinion, is a direct fit for 2008 Models, is an Upgrade for 1998-2007 vehicles, which will require YOKT60060 & MKT9.5, see Vehicle Application tab for more info
Gear package 100 series
The gear package includes the rear YOKT60060 yoke since it is required for 100 series. You will need the YOKT35100-
http://www.justdifferentials.com/GPTOY100-4-88-2-p/gptoy100-4.88-2.htm
Gear Package Kit Includes:
Nitro front ring & pinion
Nitro front Master Install Kit
Nitro rear ring & pinion
Nitro rear Master Install Kit
front pinion pre-load spacer
Rear pinion pre-load spacer
Rear Pinion Yoke
Tech Note:
1998-2002 100 Series Land Cruiser's require a 29 spline front YOKT35100-MULTI
So for a 98 LC w/ factory rear locker I'll need GPTOY100-4.88-2 and YOKT60060? Thanks
flipstick
