zukrider
Picked her up in Chicago, 1/8/16, @ 148,450 miles. Belgium Green Pearl.
In the 1000 mile road trip home to Denver, I found it needs some front end/steering parts, no surprise there. since home, and driving it to work, its starting to burn oil, so valve seals are due. The t-belt is at 8k, so thats a plus.
Forth coming maintenance includes:
-Oil change
-Full general inspection
-Coolant drain, flush, fill
-ATF drain and fill
-Steering parts, i.e. pitman, idler, tie rod ends and adjusters.
-Suspension parts, i.e. ball joints, control arm bushings, trailing arm bushings, panhard bushings
Forth coming mods include:
-2" body lift from 4crawler.com
-35" tires, possibly wheels
-Rear corners trimmed up and capped off
-Sliders
-Front winch cradle, eventually a full bumper build
-Full skid plates
-CB install
-Stereo upgrades
-Cargo shelf/dog barrier build
-Roof rack build
-Rear bumper build
-Plastic trim color change
-4.9 diff regear with Sport front housing and ARB
Most of these will happen before May, as i have a Moab trip to make.
Longterm Mods down the road:
-1UZ-FE V8 swap
-NP 203/Atlas 3.8 swap
-Oil change
-ATF drain and fill
-Sliders
-Full skid plates
-CB install
-Stereo upgrades
-Roof rack build
-Rear bumper build
-1UZ-FE V8 swap
