1997 Casita off road project $6500
Jiwa
1997 Casita off road project. $6500
As the title said it is a project, the build is maybe 75% done, there is a laundry list of stuff that needs to be done which i will be adding tomorrow, i will also be adding all the work that has been done. I am hoping to sell it to someone that REALLY loves these things, but i am moving away from a towable and shopping for a FWC.
here is the OG thread when i was totally FIRED up on the project.
http://www.expeditionportal.com/forum/threads/102170-Off-road-Casita-project
I changed the floor plan and eliminated the rear dinette and made it into a permanent bed with storage under it and room for a 40 gallon water tank
things that have been done or purchased..
- new water heater
- new 40 gallon water tank
- new sub floor
- new bamboo floor
- new TEAK cabinetry and counter
- new sink
- new stove
- sub frame
- new axle and springs (torsion axles off road are garbage IMHO)
- new extended hitch with mesh for supply's, included MAX COUPLER
- battery tray
- rear tire carrier and extended bumper
things that will need to be done
wiring
- interior lights
- light switches (should you feel the ones on the lights are difficult to use)
- run battery wires to the new location up front
plumbing
- attached drain to sink
- attach water to sink
- port and install the new water tank
- install and wire in new water pump
- install and wire water heater
- new black water and grey water gate valves
- leak test grey water outlet
Install new reefer and seal reefer compartments, will also need a new gas line run from the black pipe to the back of the refrigerator
ill update the list as i think of stuff.
Tazman
Nice job on the wood work and redesign. Put a queen sized mattress, and you could have an inexpensive comfortable start. Casitas seem to have their following and are impressive Offroad even stock.
