Isuzu NPS 300 camper build
ozzyfishaman
I have engaged a company in Geelong called VMS (Vehicle Modification Specialists) to build the shell for me, then I will do the fit out to completion.
There is a slim chance it will start before Christmas but I'm not banking on it.
Hi 4x4 Coaster,Hows the build going,do you have the walls up Yet :wings:
Cheers ozzie
4x4coaster
The assembly is finished, just waiting for the seal that fits to the pop-top edge, should get it back in a couple of days.
here is how they did the wall to floor join. Folded sheet metal glued & riveted to chassis, then wall fitted with adhesive & riveted from inside, and after all walls are fitted, the floor is glued in and riveted from underneath so a very good join is achieved.
The vertical edge of the folded section is 30mm, same as the floor thickness, so it is not visible from inside the body.
4x4coaster
Here are some pics of the body finally back at home!
.Already started putting holes in it!
Toilet cassette access panel
jordanP13
