Motor mount replacement
montero98ls
Searched a bit and didn't really find anything, maybe I overlooked, but I need to replace my motor mounts on my 3.5 DOHC was wondering if theres a diy somewhere. Seems pretty straight forward like most V engines I've done before. Any tips I should know about?
jeep-N-montero
Straight forward indeed, put a block of wood on top of your floor jack to raise the engine and replace the mount, should take about 10-12 minutes each.
Swank Force One
Pretty sure i know the answer to this, but does anyone make aftermarket mounts? Or am i just doing a gut 'n' fill with a poly kit?
Inyo_man
Don't piss down my back and tell me it's raining.
The two front engine mounts need replacing on my 2002 (3.5L).
The FSM removal instructions have you disconnecting "everything" before raising your engine.
I was hoping the process would be closer to jeep-N-montero's suggested strategy.
...looking for anyone who has completed this repair and is willing to share how it went.
Cheers.
montero98ls
That's how I did mine, I have the DOHC though. I had to really Jack it up, even removing the plastic engine cover the intake manifold started to touch what appeared to be the cruise control cable box on the firewall. I did get it done without damage. I would imagine a SOHC would have more room since the intake manifold isn't as big.
Inyo_man
Thanks for the response.
I referenced my Haynes after reviewing the FSM, and the Haynes gives the "easy- jack and swap" directions for the front mounts.
Parts are on order...
Cheers
