Bad oil leak. Need advice.
KarmannMarco
Hi guys. The truck in questions is my 1996 2nd Gen SR.
It's a bit of a read but I would appreciate some feedback.
Yesterday I noticed my oil pressure was lower then usual and I could hear the lifters ticking so I though to myself its burned a bit more oil the usual and its low ( my truck does burn and I usually need to add a quart every 3-4 weeks )
So I decide this is a good time for an oil change and fill up. Upon examination I noticed the whole underneath of my truck is coated in oil. So I drain the oil and only about 2 quarts come out. Oh oh.
I cleaned the whole underneath , put a new filter on there and filled up with 5 quarts.
Check underneath and all seems dry.
As soon as I start the truck , within 10 seconds it starts drippin constantly. About a drip every second , non stop.
So I shut it off , I clean it up again and try to determine where the leak is coming from.
Again I start the truck and this time I crawl underneath to spot where the dripping is coming from armed with a flashlight.
After a few seconds I can see drips coming down from the edge of the oil pan. Particularly on the front / passenger side of the pan.
Even with a flashlight it's hard to tell if its coming from the edge of the pan or dripping onto it from above.
Here's what I know. 2 years ago / 20K miles ago I changed the timing belt , water pump , main seal (cam seals were dry so I left them ) and crankk pully bolt like everyone should do when they buy a Montero with fresh OEM dealership parts. I've never had any oil leaks that I've noticed in the past two years. The only thing the truck does is burn oil but I've always kept a close look at my oil level.
Also , my other 1997 2nd gen leaked from the cam seals and it coated the alternator with oil which I had to replace because of this. The alternator on this truck is dry and clean and anyways I don't see any oil dripping from the front or the timing belt cover area.
So I'm 95% sure it's not coming from the front of the engine.
I've has many cars in my life with leaky valve cover gaskets and I've never seen or heard of a constant heavy leak coming from the valve cover gaskets. It's usually just grimy and oily around the valve covers so I'm 95% sure its not coming from there.
Rear main seal Is a small possibility but I can't see any dripping coming from the rear of the engine.
So I'm pretty sure It's coming from the oil pan since it's sees constant amounts of oil and the leaks seems to come from there.
Unless I'm not thinking of something.
Would you guys tend to agree with me based on the above info it's leaving from the oil pan ? I've never seen such a big leak from any oil pan but it's the most logical place it's leaking from. Have any of you guys replaced this seal ? How many hours should I expect to set aside ? Any info or suggestions are helpful. This is currently my only vehicle besides my Karmann Ghia which is not a very practical family car and would like to address this quickly and correctly on the first shot.
Thanks in advance guys.
Marco
KarmannMarco
I inspected a little further this morning.
Trying to see if it can possibly be the valve cover gaskets or the rear cam seals. Cam seals look fine.
There is oily grime around both valve cover gaskets but I see no dripping underneath them on anything. Is it possible a leak can form on the valve cover gaskets in an area I cannot see and it's routing its way through an area I can't see ?
If the drip rate is about 1 drip every second , continuously....and the leak is coming from the valve cover gaskets should I be able to see it from the top of the engine in any way ?
Im still quite sure its leaking from the oil pan but I wont know for sure until I find arrangements to let my truck stay parked for a day or two and I can tear into it.
From extensive reading it seems like I'll need to drop the axle to get the oil pan off. Not looking forward to that.
Has anyone done write up for this ?
redraif
The uphill battle begins
They sell the dye at the parts store. You can always got that route... I'm close to doing that myself... I have emptied tons of brake cleaner all over everything and it will be fine then oil all over. I feel your pain!
plh
Also check the the feed and return line for engine oil cooler. Mine was leaking too.
Ditto - same on my '92. Those OEM lines are a bit expensive. Around $80 each IIRCC. No aftermarket available that I could find. Looked into fabbing up some from Fragola components and nearly the same cost. http://www.verociousmotorsports.com/
I used these components when I added an oil cooler to my '88 for the 4D56t conversion.
Salonika
Monterror Pilot
I believe the oil cooler lines have a replaceable crush washer (not sure if that is what they are called), it looks like a regular washer but with an o-ring embedded in the middle of it. I replaced mine a few years ago. To me that is the most likely explanation for those lines leaking.
Never heard of dye being used in the engine oil, but I guess if the dye can tolerate the heat of coolant it would work in oil as well. Good to know. oem_evo_oil_cooler_seals mitsu.jpg
Androvers
Those crush washers were fine on mine but the return line was leaking from the rigid to flexible transition in the line.
1994 LS 3.0 Liter
czd3my
I cut the ferrules off my lines, used a good quality oil hose and Norma clamps and have had no problems. They don't see really high pressures when they are thermostatically controlled, by the time the thermostat opens the oil is warm and 60 psi is probably the high end. Of course it's just a suggestion and YMMV.
Goldenbora
