LR3 without airbags??
zelatore
Correct me if I am wrong but I believe Zelatore has a solid roof. EDIT: I may be confusing his with another truck.
No, Zelatore has a glass roof with many, many cracks in it all spreading from a rock chip I picked up in Sedona a couple years ago.
I really should get that fixed one of these days, but with the rack you can't see it much from the top and the rear seats are never used so you don't see it from the bottom. Meh....
jhawk
I'll look for pics.
Basically the knob pulls off, so you can remove the cover plate.
I then cut off the stalk of the switch at the base.
As far as the cover plate goes I used fiberglass resin to fill in the hole and shape it.
Jim
This is my old truck. It has the AB conversion, new suspension bushings,tires etc. I took pretty good care of it, but within the last month or so it started falling apart.
The truck started to idle rough when cold. The AC would blow fuses with the fan above about half. The final straw was a parking brake fault that would shut down the truck. It's AZ pinstriped to hell also.
I would run from it, I did.
Shoot question my way.
Jim
This Red Land Rover is your old truck??
Ancientsojourners
