Wheels and Tires
cleansweep
I have just purchased a 4x4 Sportsmobile with Eagle Alloy aluminum wheels with 285/75/16 tires. The prior owner has told me that the vehicle weighs in at 10,000 lbs loaded. I will be doing extensive travel fully loaded with an additional 350 lbs off the rear (small motorcycle etc) through Latin America with some offroading.
The current tires are 32-33" diameter and an all-season tread. I want to at least replace them with a more aggressive tread tire (BFG T/A KO2). I am considering going to a larger tire size as well. Either same diameter but wider (305/70/16) or taller 35's (315/75/16) Besides dealing with constraints of the wheel wells are there other concerns I should consider? ie Should I worry about added weight/dia/forces causing front end components to wear more rapidly? Universals having more strain due to slightly sharper angles if I go with 35's?
I believe the vehicle has a total of 5" lift with Agile's RIP suspension set up installed BTW
Any advice on this would be greatly appreciated. The prior owner has been tremendously helpful with me on a multitude of questions but neither of us know much about these topics
Thanks.........
cjken
I've got 35" KO2's on mine and RIP kit
They fit no problem.
Mines pretty heavy and they have been great!!
stormlover
There are not many options in a 35" or 315 tire on a 16" rim. But before you go to 35 or 37" the most important question is the gearing. 4.10s are a good match with 35" tires and a diesel.
cleansweep
It's the 460 gas engine with 3.73 gearing. It doesn't have quite the torque of a diesel but still 400 ft/lbs at 2200 rpm.
zhukoveli
