How about an update? A few weeks ago I was able to get my hands on some Autocraft Slinky Long Travel suspension.  It was just in time for Cruise Moab, literally.  I drove to Moab with my OME suspension and met Darren from Autocraft and Justin from Redline Land Cruisers at Grandpas Garage in Moab and we did the install just in time to make tech inspection.
I will be writing an article for TCT magazine to give a review of the suspension but it will be less focused on the actual install, and rather the performance and comparison of the suspension to my old OME stuff etc.  So here's a few pics from the install.  Overall, it's a very straight forward installation.  My installation didn't require a few steps such as some kind of caster correction and extended brake lines.  I already had those, as well as adjustable track bars (panhards).  This resulted in just a swap of the coils, shocks and swaybar spacers and bumpstops.
Remember to loosen the track bars and control arms, once it's up on jackstands, just enough to allow free movement of the suspension.  Retighten them once the truck is back on the ground on it's own weight.
Getting before measurements.
Old stuff.  OME J coil + 2" coil spacer
Here's all the new stuff.  After taking before measurements and knowing with the goal was for new ride height and load capacity we chose the set of Slinkys that would best meet the goals.  I ended up using 75mm Heavy rate Slinkys on all 4 corners.
OME L shocks compared to the new Autocraft spec ICON 2.0 shock.
Front coil comparison.  Front OME J coil on the left, Slinky 75mm heavy on the right.  Note: I lost a good 2+" of ride height with the new setup, but gained about 6" of travel.  Lots more droop available with the Slinkys.
Both set of front coils
Fitting the front shocks
A couple notes, the shocks come with a pair of nuts for each end of the shock. One larger nut and a jam nut.  Tighten then enough that there are two threads left exposed after the jam nut is on.
other side
