Considering CVT or Tepui and have a few questions
Pilotamis
I'm going to purchase either a McKinley Extended Summit Series from CVT or a Kukenam XL Ruggedized from Tepui.
CVT lists their tents at 108lbs on their website. I assume this is a typo or very old information. Tepui lists their Kukenam XL Ruggedized at 210lbs w/out annex. I'm waiting to hear what their annex weighs. Given that they are so heavy, do you see any issues with mounting them on either a ARE or Leer truck cap? ARE lists a HD model that just came out as having 550lbs max rooftop load while Leer lists their's as 150/400lbs depending on model. With the tent and 4 people thats around 650lbs total. Is it going to last 12+ weeks straight of use? Ideas for a workaround KEEPING the cap? I believe a Thule system for over the cab is rated at 165. Again not sure if that's moving max or stationary.
Can you also add a fully enclosed awning to this set up? RTT one side and awning to the other. We're heading to the Yukon, NWT, BC and Alaska mosquitos are going to be a problem. We'd like somewhere to eat that provides some relief from the tiny hellions. Again, more weight.
Window awnings, how do they handle the wind? It seems very flimsy.
What does each one do really well and what areas could each work to refine? Not a roasting, but your opinion from your experiences with each.
A few details about this trip that may answer some questions as to why I'm looking at these 2 and not something smaller. Plan is 12 weeks minimum. Actual trip duration depends on when we can leave. 8/8/16 is the absolute latest departure date. Our plan is to leave Buffalo NY, cross into Canada then explore. There's 4 of us. Wife, 3 y/o, 4 y/o and myself plus our dog. Vehicle is most likely a 13 or 14 F-150 FX4 6.5' bed. Wife has nixed any idea of anyone besides me and the dog from sleeping FT in the bed for the trip. She wants us all (no dog) to be able to fit/sleep in the RTT to watch a movie or read before bed. Truck bed will be equipped with a sleeping platform for either the kids or us so we can have us time. She's got needs. lol. Plan is 1 night a week at a campground and the rest either backcountry or parking lot. If you have a better solution I'm open to it. I'm currently in Saipan so I have no chance to see or use anything before having to buy it. Already it's looking like 4 weeks at most to buy and prep everything before we leave.
thethePete
Although I can't speak to your specific situation, most times when a Mfg lists a roof load it's a dynamic load, IE it can take that while driving down the road. I would ask them if that load rating is static, or dynamic. If it's dynamic, I would think you should be fine, since 550lbs bouncing down the road will have a higher load force on the roof than 600lb-ish static.
Box Rocket
I can offer some help regarding the Tepui Tents and give some insight on cap mounting etc. Give me a call at your convenience and we can discuss. 801-710-8110
Cheers
Motus1
Box Rocket
You may already know this but the window/rainfly support rods should go through a small slit in the lower skirt fabric instead of underneath like you have it in the photo. With them underneath the skirt like you have it the skirt can't lay flat and will collect rain water. Putting them through the slit in the skirt will let the skirt lay flat and water can run off.
Looks great though.
Motus1
Looks great though.
Makes sense and I never noticed holes in the skirt.
WillBeck
Wow, that trailer dwarfs that tent.... Not an easy feat.
To the OP, I recommend calling Adam (BoxRocket) he can address every question you have.
stingray1300
The only positive thing I can add in the comparison, is the difference in customer service. CVT has, well, "issues". Tepui is straight up light years ahead of others. I talked with both extensively. I bought Tepui. (they also have an edge in the Q.C. dept.)
Clemtiger84
