My trailer power system
ikk
I just converted one of the 12 volt cig plugs they have to Anderson since each light comes with one.
ikk
No Hijack at all..I debated over a portable system vs the in trailer route. I like that box.
Box was around $25.
Not done yet, has a 28 ah battery. When that goes I would like to go with a lifepo4 50ah. I'm trying to find some mounting clips to mount a few torch lights next to the battery charger on top.
I was going back and fourth as well, decided on a box because I can take it anywhere. As well as use it in my house during an emergency.
dakota123
Thats awesome :) sounds like a good use to connect the trailer battery to the vehicle alternator and just be able to unplug it when its not towed
DZANINOVICH1
Is your trailer battery connected to your tow vehicle? If so, how, and is that where you are using the battery isolator you mention?
Thank you
Semi-Hex
Enfant Terrible
One standard connector! For the cords on lights, connections to power sources, battery chargers, inverters, you name it.
With these, I can also check each individual draw of each of my fixtures. This is a growing industry and a lot of people want to know how much power is really being used with a certain fixture.
Clemtiger84
