Rockhounder
Hey all,
I have an 88 suburban, with the stock 700R4, 3.42 axles, and 33" tires. I like how the rpm's at highway speeds are really low, if you keep it at 55-60 mph it feels like 1200 to 1500 rpm's and gets noticeably better gas mileage.
But.... I am doing a LOT of high torque driving by going up and down the hill from Big Bear all the time, and am concerned that the tranny is just not up for the job. It overheats like crazy, even with the 3 extra tranny oil cooler radiators, and the radiated large capacity oil pan. Going up the hill, in 3rd, or even down to 2nd, on hot days, I literally have to pull over several times to cool off (tranny temp sensor gets to 210 degrees, and I pull over, if I don't, then at 230 degrees or so, I start smoking, and blowing radiator fluid out the vent tube on top) Some people told me that it is a bad tranny, but this is the 3rd tranny, and all before have done the exact same thing. Was embarrassing going up the grapevine from the north, in the emergency lane pulling a trailer, having to be in 4 low at 5mph, just to get up the hill.
I wish to upgrade to a better tranny, have heard that the 3/4 ton version is better, but do you know if anyone makes a swap kit with all the needed changes (mounts, fittings etc)?
Or does anyone have any other advice? It seems like there is much more power available in the engine, so if there was a stronger, and less heating up tranny out there that is an easy(relatively) swap, then I want to do this. I am tired of driving up the hill, in 2nd, going 20 mph, constantly pulling over to cool down tranny, yet only using perhaps 25% throttle, and engine is nice and cool. Towing our boat up the hill, we did 10mph, and with literally had to pull over in every single pullout, to cool down. Normal 1 hr trip to big bear took 5 hours that day... bleech...
