Built a Swingout on a Cayenne
eurosonic
I do fabrication on the side so this was a project that was brought to me. Car didnt come with a spare tire. Owner does mild offroading and tows a racecar trailer so he needed a place for a spare. Before it was on the roof.
I designed this to fit under the factory bumper. I wanted to integrate it as clean as possible and keep it tucked close to the body. It was quite a challenge to work within the constraints of the factory bumper but I made it work. Check it out.
2004 Cayenne Turbo.
Made a plate to fit to a flat surface under the tail light.
Mocked up the spindle.
Alot of careful measuring and trimming on the factory bumper
The swingout arm contours with the edge of the bumper.
Added the latch and the carrier. Also added a second mount connecting spindle to the hitch.
Final result. Unit is very sturdy with essentially zero play.
Nice and tight
Clawhammer
Nice work!
But... I don't know about California, but around here having half your license plate covered is a sure way to get pulled over.
Herbie
Rendezvous Conspirator
Nice work!
2nded. May need to find a way to relocate it up to the glass or farther curbside on the liftgate...
Renntag
It's common to mount the license plate to the spare tire (cover).
Sent from my SAMSUNG-SM-G870A using Tapatalk
dr_r2r
Looks good! I tried to put a spare on the roof, but chickened out at the last minute. Too heavy with the potential of becoming a projectile missile. I'd probably just get a hitch mount spare tire carrier.
