PICTURE THREAD: Post up your Mobile HAM setups
lugueto
At first I thought the little radio was cool, I actually still think the concept is. But for $210 you can get waaaay more bang for your buck. Not to mention you can get the same radio for 80$.
They also sell a rebranded Baofeng UV5R for 90$ on their website. They sell expensive chinese rip-offs of the cheap chinese radios? That doesn't sound like a smart business plan.
Someone posted about worrying about protection for the radios should something go wrong. I personally think that radios might be the least of your problems when you're knee deep in water inside your vehicle (A few buddies have been there).
A lot of people here use overhead consoles for installing comms, this might be the safest place. Mine is in my shifter console, I have a quick disconect that should save the radio if water comes in (If I can manage to disconnect it amidst the chaos) but then again, my car is worth more than my radio and the latter isn't gonna drive me home, so as said: common sense dictates you should avoid these situations in the first place.
I decided to install a Ham setup in my Jeep and trailer. Since I like being overpowered, I installed a little bit too much. That being said, I'm happy with how it came out.
Here is what I've installed:
Jeep:
Uniden BDC536hp scanner with GPS
Laird Technologies WPD136M6C-001 scanner antenna on custom NMO mount on front bumper
Pavement optional radio rack
Uniden PRO510 CB Radio/PA
PA speaker with 300watt amplifier
RoadPro RP-550 36" Ring Tunable CB Antenna(usually not installed)
Icom 5100 VHF/UHF Radio
Diamond NR73BNMO 2m/70cm antenna mounted on driver's side cowl in NMO mount
Icom 7100 Radio for HF
WestMountian Radio "CLRspkr" DSP/Speaker
Little Tarheel HP screwdriver antenna on modified Cooltech "Ultramount"
Tunematic screwdriver antenna controller
RF bonding *everywhere*
The VHF/UHF antenna is mounted on the driver's side cowl.
In this picture you can see the PA speaker with a round white sticker on it behind the grill, and the scanner antenna mounted on the front bumper. Since the scanner antenna is receive-only, I don't need to worry about the terrible SWR I get from this location.
My screwdriver antenna is mounted near the license plate holder. It does pick up noise when I hit the brakes from the nearby indicator lights.
You can also see the CB antenna on the post in the center of my rear window. This antenna is on a quick disconnect and I don't run it very often. My screwdriver antenna can RX the CB bands just fine, and I don't think I want to talk to them anyway. I have the antenna cable run just in case I need it for a group run. The CB is mostly used for it's PA function when offroad to communicate with spotters.
I had to use a cupholder as my IC-7100 mount so that I wouldn't get gorilla arm while using the VFO. Since I like cupholders, I installed an extra one on a RAM ball on the passenger grab bar. The extra cupholder is sort of visible in this next photo hanging off the front of the dashboard. I still have two functional cupholders, and I am still able to fold the passenger seat forward to get into the back.
You can see the ID-5100, the CB radio (more of a PA really, but there is an antenna for it), a mini-mixer, and the speaker up on the radio rack. The rack is thin enough that the GPS receiver in the ID-5100 works correctly in that location so I am able to use the "find/scan nearby repeaters" function in the radio.
The mic and antenna controller for the HF antenna is down in the driver's side footwell next to the 4wd selector. The antenna controller is kind of hard to get to here, but I'm not really worried about it since I don't plan to debug my HF setup while moving. It is easy to hit the autotune button in this location and that's the only button on the antenna controller that I will ever touch while in motion.
I swapped the stereo with a single DIN unit, and installed the scanner in the dash below the stereo headunit. This scanner does not have a removable faceplate available for it.
The whistler scanner that does have a removable faceplate does not have location-aware memory, so I decided that a geo-aware scanner that is harder to mount is a better call then a non-geo aware unit that is easier to install.
Trailer:
Icom IC-7100 all band transceiver
N8XJK Boost Regulator for IC-7100
10m half-wave vertical, used as a pole for a 20m, 40m, or 80m inverted Vee
Windcamp Gypsy Adjustable Dipole
Diamond SG7900NMO 2m/70cm antenna
Uniden BCD-536hp scanner
QD mount for Hamstick antennas
The battery booster is needed here since my trailer is all solar powered. The voltage drop on the dual AGM batteries in the trailer at 100w of output power was so much that the transceiver would shut down.
You can see the 2m/70cm antenna, the scanner antenna, and a 20m hamstick in this photo. My driveway isn't big enough to deploy the inverted Vee.
texascrane
Finally got around to installing my Yeasu 8800R in 2006 LX470. I used a gamiviti antenna mount on the drivers side of the hood with a comet 2x4SRNMO antenna. I used a larsen NMO cable along with some 10 gauge powerwerx zip cord.
I ended up putting the radio body in the passenger side of the rear trunk area that holds the first aid kit. I drilled some holes for air flow - I don't think it's going to be an issue mounted this way. I can throw the cover on and you can't tell that anything is there.
I mounted an external speaker up in the passenger footwell and then put the radio head just in front of the ashtray. I'm pleased with how it turned out and it appears to be functioning really well.
gary in ohio
The radios are just QYT KT 8900, you can get them on ebay for under $100... They are neither rugged or legal anyplace outside the ham bands.
Clearly rugged radio is just sell overpriced crap and not caring about license issues. My bet based on the 40 channels would be 28 GMRS/FRS channels, 5 murs channels and 7 weather channels. The password protected freq is a way to hide the sleeze... Anyone want to call and get the password?
Rezarf <><
@ unusedusername, that is an amazing setup man. Lots of thought, time and coin in that setup for sure. Everything was done so cleanly man, enjoy it!
HS10
Jeep Wrangler with Yasue 857D and Steath Telcom 3910 Antenna System
Great combination. Central US to the East Coast Daily while mobile, and band tuned > 1sec
attachment.php
AFBronco235
Crew Chief
Not sure if this counts, but here is what I came up with for my UV-5R in my center console I got out of a Ford Raptor.
attachment.php
Turns out the MP3 slot holds the battery clip perfectly.
oskarf150
