Qbombs TJ and Trailer Build
quadabaum
Thrifty Overland
The lunette ring was primed today.
And coated with textured black.
Sent from my SM-G900V using Tapatalk
quadabaum
Thrifty Overland
Did an SOA and installed the axle. I'm going to roll coat the tub with tractor enamel (looking at tractor supply). Anyone know of an enamel paint that's close to the 06 TJ Solar Yellow?
quadabaum
Thrifty Overland
The fiance helped lay the 2nd coat of bedliner and sand the outside of the tub. Going to spray paint the outer tub.
FosterWV
Baller On A Budget
Nice TJ and cool trailer build, what brand bedliner you using?
I was looking at Por-15 but it's not cheap!
quadabaum
Thrifty Overland
I actually put por15 on the frame and bottom of the tub and didnt even use a full quart. It goes a long ways. I used herculiner bedliner on the inner tub and rattle canned the oitside of the tub.
Not a good paint job but it's a paint job none the less. Rattle can yellow.
quadabaum
Thrifty Overland
I probably would've taken you up on that if I hadn't of already started spray painting. It's probably not a perfect match but close enough.
Mitch502
The Harbor freight gravity fed guns are like $15 on sale and are excellent for stuff like this. You can even throw them away after wards if you don't want to clean since they're so cheap!
quadabaum
Thrifty Overland
The safety chains were delivered and the trailer is officially tagged! I am pulling the trailer to and from work the next few days as a kind of shake down test before heading to Florida friday.
DanoWall
