Post Van Parts For Sale Here please
Jsweezy
Just wanted to update and let everyone know. If your interested in a 55 gallon aft axle tank. http://www.torgersonswrecking.com/ In Chehalis, WA has them (diesel) along with the crossmembers and everything associated with the tank. They pull it so you would just have to call ahead of time to get it ready to go. I am in no way affiliated, I am just passing on the info.
Abitibi
Thanks for the info! Mine is the smaller version (there were 2 sizes as far as I know) and I'll consider this for sure.
Cheers
David
Sent from my SGP511 using Tapatalk
Bikersmurf
Cheers
David
Same as my 1997 and the 2001 I got parts from... Although we could likely loose the under-mounted spare and run two tanks. :D
cjken
I have some 2.5 inch steel spacers that I was running on the rear of my ambulance.
Also a pair of Dana 60 front dually hubs available.
I don't forsee needing them since I switched from H1 rims.
They would work for someone looking to run H1 tires and rims on 4x4 van.
1der
FS: Ford Econoline van 92 and up Rear Pop Out windows
Have a very nice set of the rear pop out windows to sell.
These are the dark bronze tint, they have all the latch hardware, backing plate and screws. The securing screws are not the factory gold capped screws, but they work just as well. The plastic rim pieces are all clean and ready for install. I am even including butyl tape seal with the set. If you have ever installed one of these sets, you know how much of a pita it is to clean off the sealant from rim surfaces!
There a couple of very light thin scratches on the outer surface of each window. I tried to get pics but they are not photograph-able, and you have to be close up to see them.
$180 plus shipping
mgmetalworks
There are 3 sets of pop out rear windows (clear glass) at Sherwood OR Pick'n'Pull. All the parts are there, good shape. This weekend is a half-off sale too.
primitive
Cleaning the garage and found
Lift blocks
Original Quigley blocks and u bolts 3.5 inches 25.00
Aftermarket blocks and u bolts 5.5 inches, only on van for about 2 months 50.00
Both came off of a 2006 E350 at different times.
I was there last week and could only find one set that were painted black. Now am looking for the 40% side door. Have all the hardware, just need the glass.
mgmetalworks
Clearing out some stuff that is just taking up precious space in the shop.... prices DO NOT include any shipping charges. non-local buyers to pay all shipping expenses.
Fresh NV271, new bearings, guides and seals, new chain, updated shift fork, new input/output flanges, 34 spline input.
$750
Factory E-series steering stabilizer mount and shock.
$75
2013 E350 factory running boards and hardware, great condition.
$150
2013 E350 chrome front bumper and lower valance, great condition, no dents or scratches
$200
2013 Quadvan 4x4 conversion parts. Taken off of my personal van at 22,000 miles. Some parts that go with this 'kit' are still on my van and will be removed within two weeks. Includes factory rear springs and lift blocks, shock mounts, radius arms, trac bar mount, radius arm mounts, spring perches and misc. parts. Coils included too. Great DIY project. Easy install. $4500
