where is Lower pressure to fill up with AC/PRO
newworld2004
where is Low pressure port for 98 Montero ?, so I can fill it up with AC pro refrigerant ? and does it take 134a?
Thx
JohnnyBfromPeoria
I'm Getting Around To It
Yes, it uses R134a. The ports are designed so that you CAN'T hook them up incorrectly; the high and low side fittings are different sizes. The low side fitting "should" be near the compressor. Just remove the black plastic caps until you find the one that the hose fitting on the bottle fits.
There are a zillion You Tube videos on this.
John B.
newworld2004
John B.
Thx, I did this for 2004 Honda Pilot, was able to easily found Low pressure port which mark with "L" blue cap on pilot, I will look again to see if I can find it. Thx for quick reply.
mnewxcv
the ac pro website has a port locator tool. Not sure if they have the montero listed but check it out.
gp01
