1997 Ford F-350 XLT Diesel 4x4 with Ambulance body-Atlanta $10,999
Eaglefreek
Eagleless
Not mine.
http://nashville.craigslist.org/cto/5586432558.html
Ball
Pre-05 e350. I hope you like j-turns.
Edit: Actually if someone knows a way to remedy the 60ft turning circle PM me and I'll buy and modify this (and post results).
I have access to a metal shop and welder. I'd also have to tig weld some way to increase the height a bit...
Ball
Actually an F series, but that is the solution regardless- install '05/newer front axle/suspension...
Yes, I meant to say F350.
I've read about the swap, but nobody has seen fit to document the process. I'm surprised nobody sells a kit.
Rovertrader
Supporting Sponsor
Check Clydesdale 4x4 as they use that setup on the E series conversions, and shouldn't be too difficult to fit to F Series...
Rovertrader
Supporting Sponsor
As they say in the fab world- anything can work, it's just at what cost?!
I would think it would work, but you will have additional cost like hubs, etc...
oskarf150
