Rear Differential Locker
freewayross
Hello, there's a 93 montero with differential locker in local junk yard. I want to know what all do I need to pull from that car to retrofit my gen 2.5 with rear differential lockers. If you can provide me pics of part if you have a locker that will be great.
Does it require the differential swap?
Thanks
jeep-N-montero
Thanks
They are different size rear axles, read a bit and you will discover the differences, start with this thread http://www.expeditionportal.com/for...-quot-are-the-axles-in-a-92-SR?highlight=weak
plh
'93 may have 4.88 rear gears (pretty common) also will be a 9" ring gear. Your Gen 2.5 won't be any of this. In fact there were a few different final drive ratios in the Gen 2.5s. Verify what you got first.
oskarf150
