Coachgeo
I'd ask this at Steel Soldiers but anything EMP is a topic that is against the rules
For ****s and grins on my LMTV (to be fitted out as ruff Expo rig) thought I'd stick with military type wiring for Aux. things that has a bit of EMP protection. Not really wanting to discuss the pros-cons, the chance of needing it or not etc. Plenty of discussion other places on that.
For example; the LMTV uses 12v sealed beam head lights (3prong) except the wires are prefixed to the prongs with military wires and covered in something.... Epoxy? . Pigtail from light are attached via special crimps to the trucks harness. For now if all possible I'd like to cut the wires and attach 3 female spades so I can use standard 3 prong sealed head lights. *Year+ down the road when $$ allows go to military 12v LED's.
so question is how to potentially get a little bit of EMPish protection which would also give some level of waterproof too with a Civilian Headlight with 3 prongs. Will below idea get me close at all.
1. Use military wire and crimps to end up with 3 female spades.
2. plug spades to headlight (ensure all is correct first)
3. Keeping in mind being able to change out a bad headlight in the future........ Fill/encase all spaces at back of light and over spades along with being well overlaped onto rear face of headlight with material from?
.... Glue gun?
.... Silicone?
Thought is that by using either glue gun plastic or silcon it can be removed; though a bit of a PITA to do it, when needing to switch out a headlight. Hopefully by time first light goes out again I'd be prepaird to swap to military units anyway. Got one headlight out now.
? Would it be better to wrap the area with Tinfoil first then glue? Silicon? as described above. Obviously before tinfoil wrap all exposed metal must first be completely covered (liquid tape?) so tinfoil can't come into contact and cause a short between male spade material at back of headlamp. Probably should do this after # 2 above anyway.
*Military 12v LED are about $400/pair and up right now while reg. 3prong sealed beam is $30 pair?
.... Glue gun?
.... Silicone?
