Fenders
wagex
that's what i used on my trailer that is running 275/65r18 i did have to do a little bending to spread the bottom length out a few more inches to get more coverage but they worked fine im actually switching to 265/75r16 pretty soon which are about a half an inch smaller than my current tires in diameter. i did buy mine on ebay though, but same dimensions.
PCO6
I used similar fenders on my trailer along with 245/75R/16 tires. The original fit of the bottom length was tight so I split mine at the top corners by using a 4.5" grinder with a thin cutting disc. I cut 2 slits at each corner, spread them to the length I wanted and then welded them back together. It was quite easy to get the clearance I wanted.
Hopefully these pictures will help to explain what I did ...
... original bad fit.
picture.php
... original fender on the right and spread to the desired length on the left. Note the 2 slits in each top corner.
picture.php
... slits welded up.
picture.php
... final fit and painted.
picture.php
V45W_Proto2.5
