2000 Mitsubishi Montero
RttH
2000 Mitsubishi Montero with 149,000 miles. Beige and needs paint, but NO rust!
-ARB Brush Guard with PIAA fog lights.
-Safari Snorkle.
-Sunroof
-Thule (4) cross bars (used to hold RTT).
-Custom Sliders.
-Old Man Emu Heavy Duty Shocks and Springs
-ARB Front and Rear Lockers
-3.15 Low Range Gears
-Cooper AT3 31x10.5x15 (5 ea.) rotated every 4000 miles, new at 134,000 miles. I have run 32x11.5 and 33x10.5 without any issues of rubbing.
-factory alarm system.
-Rear view mirror has back up camera.
-rear bumper has additional back up spot lights connected to reverse gear.
-Replaced rear door hinge (2014).
3rd row seats removed (gone). Window tint is starting to peal. All seats in good condition, no rips or stains. Antenna broke off years ago when antenna motor quit working. I have been using Satellite radio for 12 years.
Maintenance:
-Timing belt and other belts done at 112,000 miles (May 2011).
-Plugs and wires done at 120,000 miles.
-Diff and Trans fluid last changed at 144,000 miles.
-New battery 12/2013
-New Alternator 2/2016
-Tie rod bushings and ball joints 6/2015
-Brakes at 140,000 miles.
-Oil changes every 4000 miles.
-Passed emissions 1/2016.
-Alignment 7/2016
This has been a great rig and didn't see as much off road as it was set up for. It has never broken down and has traveled to Canada, Mexico, and coast to coast. It has a random, small leak of oil, but not enough to warrant repair. No issues that I can think of? Slight "play" in the transmission? Asking $4100.00 heinsr at gmail dot com. Location is Windsor, Colorado.
RttH
What's the rear area like? Do the middle seats fold down enough for you to build a bed platform back there for a full size mattress?
The 3rd row is missing. I didn't have much luck with seats folded flat for a bed. Maybe if I had kept the 3rd row seats. I once built a plywood platform that extended behind front row to the back door. Interior is in good condition, for a 16 year old vehicle that was a daily driver but not shiny new.
Goldenbora
