Project G-WAGEN
diesel_jim
Looking good!! I've recently bought a 1989 460 SWB (280GE), already pulled the engine out to do the OM606/722.6 conversion.
Have you swapped the injection pump on the 606 to a 603 pump to get rid of the electronics?
xracer9
delay
The project is delayed due to lack of time (first, the works for clients)
Also because we thought to install the diesel engine a non turbo OM606 manual transmission, but the diesel pump is electronic and also the body acceleration, would have to adapt him a turbo, also wanted more power and comfort, therefore we decided to install an M119 V8 with automatic trans. The new engine has just arrived this week so expect more forward before the end of the year.
We have ready 5 Hutchinson wheels with Toyo MT tires 285 / 75-16
xracer9
I can finally continue
After long time without post because the project is delayed due to customers works prior to it. There are some advances on it.
Body prepared and ready to paint
Underbody pre assembly
M119 V8 Engine and transmission pre-fitting
Wheel spacers fabrication
ILIAN
Great project. Are those Koni shocks? Which ones? Can you please document in detail what you have to do to fit M119?
xracer9
http://snorkel4x4.com/es/51-g-class
Recently bought a Snorkel in Spain for my project. Comes with all the necessary accessories for its installation and both its aesthetic and quality of manufacture will give a plus to my G.
The shipping was in 3 days and I highly recommend it.
Here is the information of the company:
JOAN BONET - General Manager
C/ Alacant 41, Nave 3 - 17005 Girona (SPAIN)
T. (+34) 972 425 065 / M. (+34) 625 595 489
E-mail: info@snorkel4x4.com
xracer9
engine mounts
We made the new engine mounts and brackets, welded on the frame and locate the engine in the final position, using Toyota FJ40 engine mounts, that are perfect in size and can be found easily anywere in the country.
xracer9
body and accesories pre fitting
Prior to painting we locate the body to the chassis in the ideal position using rubber spacers 50 mm high
We also locate the snorkel and the ARB bumper to make the brackets
otiswesty
Regular guy
Looking good. How did the body repair go with the rusty holes?
The m119 is an amazing motor. Do you have the 4.2, 5.0 or ???? 6.0...
The 5.0 was in the 1993 500GE model, Brabus did some upgraded 6.0 installs as well.
xracer9
Thank you !
After sandblasting we made patches for the hole repairs ( it seemed like frankenstein) but was ok and everything fixed.
The M119 is a 5.0 from a 1992 sl500 donor.
UtGoat
Can't wait to see the end product here. What color are you ulitmately going to go with for paint and interior?
Tho
