Gen 2.5 Transfer Case Lever - Install
All-Terrain
No Road Required
Couple quick questions...
Does this spring need to be set to the right, or to the left, before putting the lever back in? If it has to be set to the right, how do you hold it in place while you put the lever back in? My spring keeps jumping back to the left and it's very strong, so it's tough to hold to the right for very long.
Also, how do you align these forks with the lever out?
Thanks!!
SONICMASD
Search "shifter" and a couple threads with photos of the correct position will come up. Or check out my Build thread for the link and pics.
nwoods
The forks move forward and backwards pretty easily. Just move them with your fingers or use a large flat screwdriver. I posted some photos in a thread a awhile ago
All-Terrain
No Road Required
Thanks for the help, guys. Couldn't move the forks by hand, but the handle of a large ratchet worked great. Easy enough.
Henrybrowne
