06 4m50 chugging and smoke
boostin
Hey guys
06 fe180 4.9, between idle and say 2000rpm driving and free revving the engine chugs, and smokes...a lot, say like a grey color some maybe. It will build zero boost till it clears.
Seems to be getting a little worse, injectors cleaned and tested about 10000k ago, all filters done, valve set done.
Any ideas?
steve4wdaus
4WDaus "tralia"
Sounds like it has a dirty filter restricting fuel flow or air is being sucked in through a loose connection. Else check the manual fuel priming pump is screwed tight.
Cheers
Steve
pugslyyy
Would you say it is grey-white or grey-black?
White = not enough fuel (or fuel injection timing is off)
Black = too much fuel/not enough air
boostin
It's not black, white grey color.
I will try another fuel filter, maybe I got some thing bad in my tank.
Other wise I am not sure, must be lean, but can lean make a lot of smoke¿
boostin
Anther thing I noticed is the problem gets worse the hotter the engine gets, after a good drive it's much worse then half warm
pugslyyy
Makes me think it is some sort of a fuel contamination issue if it gets worse as the tank gets stirred up from driving? I would check to see if there is a low fuel pressure code stored in the computer. In my experience low fuel pressure does not illuminate the check engine light but does throw a code.
boostin
Ok I'll check the computer, I assumed for sure if it was low pressure it would set a light.
I do totally agree about the fuel, I pulled the fuel filter again and the bottom of the housing was lots of stuff and it was maybe 3000km old.
There was little rust chunks flakes and some sort of fine silver dust that was not magnetic, maybe aluminum?
New filter, chugging still there after driving but wow more power
pugslyyy
Yeah it always strikes me as silly how something that actually could impact performance won't turn the light on... but if the EGR doesn't read right then you are in limp mode.
boostin
Hey got some codes, they are past codes. I am not near my service manual, any one care to help decode these?
They are flash codes from pulling the diag fuse...
08
33
44
95
96
Any help would be appreciated,
Mike
pugslyyy
08 - P0204 Injector M/V-Cylinder 4
33 - P1605 ECU System (EEPROM)
44 - P0112 INT Air Temp. SNSR (Upstream)
95 - P1630 CAN (EGR)
96 - P1635 CAN (Intake Throttle)
gait
my very limited experience with blink codes on Canter (one episode) was that the old codes could have occurred at any time in the past and may not be relevant to current problem. In my case low boost pressure but past codes suggested engine was running backwards among others.
When I cleared the old codes and engine light still came on the new codes were very clearly associated with poor engine operation.
pugslyyy
yeah I've had the same experience... clear all the codes and then see what you get.
boostin
Ok thanks guys, I deleted them, I'll see what happens, I will be away from the truck for a few weeks.
I have had so many injector problems especially with number 4
flipstick
