Collection of Trailer Builds
senorschmidt
Here is mine! Work in progress still. But, I guess it always will be.
http://www.expeditionportal.com/forum/threads/155517-New-trailer-build
attachment.php
  • Like
Reactions: 5th
Greg_Volkman
My M-416 Overland Trailer Build!
Resto video is in my signature line. Complete build thread is on pirate4x4 under the trailer forum (same user name for me there).
RDK13
I have spent a lot of time on this site getting great ideas from all ya'll's builds. I still have a few things to do to mine however, I thought I'd share these pics of my trailer.
Thanks,
Ray
teotwaki
Excelsior!
How did the horizontal mount of the gas cans work out? I've looked at the same approach but clearance issues with removing the retention bracket stopped me.
RDK13
I went with Adventure Trailers fuel can bracket and I couldn't be happier. I had the same problem with the locking strap and decided the I would cut the strap at the bend and install a hinge. I riveted them on and it looks like it came that way since the whole bracket is riveted to begin with. You can see the hinge in behind my beer in the picture below. I also added a L bracket at the end of the strap to keep it from sliding. I'll take a picture tonight so you can see what I mean. These brackets are awesome the will hold a full can of fuel or water and it doesn't move at all. I did have to use spacers to get some clearance from the body of the trailer so the can will clear the rack I have on the tongue and I cut off the handle on the corner of the tub. I usually keep fuel cans in the brackets all the time just to keep the strap from rattling.
you can see the hinge behind my beer
Strap hinges up to access fuel/water can
RDK13
Here are close ups of the hinge and L bracket I added to my Fuel Can Carrier.
the L bracket is riveted to the body of the carrier and not the strap. this allows the strap to pivot up in order to angle the can out of the carrier.
hope this helps
teotwaki
Excelsior!
hope this helps
Awesome! Thank you! I had kicked around the idea of a hinge but I like how you carried through by riveting part of the strap to the carrier body.
abctrash
