08 Dodge Ram 2500 megacab - slow build
KSL22
Mini trip report.
I took my 11yr old boy / girl twins up to the Kern Plateau for the last weekend before school started. We left Thursday afternoon and came home Sunday. The drive up was non-eventful, light traffic all the way. We topped off at the Pearsonville shell station before heading up 9 mile canyon. This was the first time going up without 12,000 extra pounds behind me and it was a lot nicer of a climb.
We drove straight to the Monache Meadows Jeep Trailhead and aired down once we hit dirt.
The trail down to Monache is a fun winding road through the trees. It only has a few real rough sections and other than the alternate line down the slab could be done in any stock truck or SUV.
We camped on the far side of the South Fork of the Kern Thursday and Friday night. Due to the fire restrictions and real low water levels I decided to pack up and head down the hill to the North Fork of the Kern for our last night.
Of course I couldn't take highway all the way down so we split off the highway to take the Sherman Pass Jeep trail down. Unlike the trail in and out of Monache, this is a black diamond jeep trail. the road up to the trail head was a blast. It is fairly smooth with some nice rolling water bars and sweeping turns.
Sherman Pass Jeep trail was, shall we say interesting in a 20' long and not exactly skinny vehicle. There were quite a few REAL tight spots squeezing between trees, and you definitely had to plan your lines so you went through square. There was a downed log across the trail with a bypass, but I wasn't sure if I could make it around. I ended up having to take the rockier route of the two lines as I could not get lined up to fit through the other line. I still had to work the rocky line a few times as my rear diff kept getting hung up.
After that it was fairly smooth sailing other then the occasional, pull the mirrors in to fit. We even went up the big rock hill without barely a tire slip. There was another downed tree before that but it was small enough to drive over. After passing the turnoff to the Enbree Cabins and the Sherman Pass peak the trail took a drastic change. Once you start going down towards the valley the brush tightens up drastically. It seemed like a mile straight of listening to the branches rub both sides of the truck. Also found more than a few downed logs pushed to the side of the trail hidden in the brush. Next time I will turn off at the cabin and take that down to the highway.
Once you finally make it through the brush the real fun starts. the trial gets steep and the turns turn into switch backs. As if the switch backs are not exciting enough in a vehicle this size, on the down side of many of them were some fairly good sized rock shelf's. I think I had to multi point four of the switch backs and I diff'ed one of the larger rocks with my front a few times until I figured out the line. The kids were happy to get to the bottom.
I attested to air up at the highway but my compressor / on board air setup still has some wiring bugs. I got two and a half tires up prior to the relay failing me. We headed down the rest of the hill and ended up finding a spot at Fair View for the night. I set up the tent while the kids waded in the water a bit. Then we went to McNalley's for some of their famous grub. The next day we packed up and headed out after breakfast. We stopped in Kernville to fill up the tires the rest of the way. I can't wait for the next adventure.
Note: I will add more pictures and such later (hopefully tomorrow). I might edit this one for here and expand it out in the adventure section.
KSL22
http://www.expeditionportal.com/forum/threads/162328-Weekend-trip-up-to-the-Kern-Plateau
Well I did a more complete write up. Still need to add a few more pictures. Pulling the trailer down to Thornhill Broome for some beach camping this weekend. Need to start planning the next overland trip.
I have about $600 for gift cards (more if I parlay it into REI or Bass Pro) and am trying to figure out where to spend it. Seems like every purchase is the snowball that starts the avalanche of spending.
12k winch - But then I would need to either buy or build a bumper.
Front locker - But then I would probably want to re-gear which means then I would want to replace the rear L/S with a locker as well.
What is the one thing you can't do with out on the trail or in camp?
KSL22
Put the truck to work this weekend doing it's original job of pulling my trailer. We camped at Thornhill Broome beach for the weekend. Good family fun and lots of marine life right off the shore. Baby seals, sea otters, and dolphins swimming by.
Some great meals
Great sunsets
And of course camp fires.
KSL22
Finished up the switch panel for the compressor and air bags. It fits the factory coin holder or where the t-case stick would be on manual engage trucks. I did have to remove the carpet and padding from under here to make room for the tubing coming off the gauge.
I got the wiring to the compressor sorted out finally thinks to help from a bunch of people on here. Now I just need to chase down a few leaks and let the compressor run for 20 min or so to make sure I wont have anymore back country issues.
The gauges are left and right bag pressure. Below that are the left and right pressure release valve (fancy schrader valve). Left switch operates the air valve going to the bags, and the right switch operates the compressor. I have one way valves off the air valve going to the left and right bags to keep them as separate systems.
KSL22
Quick fists installed so the shovels aren't rattling around in the bed anymore. Need to grab some new "truck only" shovels.
KSL22
Also got the air bags finished with Daystar cradles. I am not sure I will keep them on when not towing. I can't see the air bags doing wanders for my up travel.
With the cradles, removing the bags is as easy as pulling the air line then undoing the top nut.
I am thinking about seeing if these bumps will land in the cradle in place of the air bag.
KSL22
Tire stuff before and after with the bags and cradle.
Well I tried to straighten them...Here is the stuffed and extended bags.
Looks like my thoughts are confirmed and these will be coming off before my next desert trip. The question is will i need rear bumps with the stock springs. They only compress so far. :):)
Bcmmp9
Beautiful build. I'm Building my 1500 at the moment. I'll be getting a 2500 next year and passing my 1500 off as a daily or for the old lady.
KSL22
I haven't updated this for a while mostly because I haven't done any real upgrades. I have been using it a bunch.
Since I last posted I added a Dometic CFX-65 dual zone refrigerator/freezer.
Here it is strapped in with the rest of the gear before we headed down to Truckhaven and Ocotillo for TDS desert safari.
When I got down there I decided to experiment with pulling one of my sway bar links. What a difference, I don't know why I didn't do this earlier.
The next day we went over to Anza-Borrego and did Lower Coyote Canyon to the end of Lower Sheep Canyon, hunted sculptures, hiked "The Slot", and drove up Fish Creek Wash to the Wind Caves.
Coyote Canyon once we got past the traffic jam.
From the Slot
From the Wind caves
chilliwak
Wow:Wow1:Ksl, those are some great pics. Looks like you had a blast in your truck on that trip. Thanks for posting up. Cheers, Chilli...:)
KSL22
A short while after the trip to Ocotillo and Anza I got a message from Chris Ridgeway (@RIDGE on here) about doing a weekend run. Some of you might recognize him from his recent spot on BBC top gear. I'll probably have to go through his agent to scedule future trips.
After some back and forth on the diferent trails we could do, we settled on seeing how far we could get on the Mohave Trail. The plan was to go in Afton and make a right at Kelso Cima Rd taking it back down to I40 taking it back toward Apple Valley. I met up with Chris and Kristal in his Jeep TJ and Kristal's son Nick in his Dodge 1500 and we hit the road.
Once we hit dirt we all aired down the tires. I loaded some waters in the cab and we headed down the trail.
At the Mojave River crossing. I made it through dry. Chris's Jeep on 33's took in a little water through the floor.
Had to get the train trestle pictures
We saw a mine coming out of the canyon so we hooked a left to go check it out.
This is why we come out here.
KSL22
We found a nice spot for lunch and ice cream. Kristal found the swing and Chris was more than happy to give her a push.
As we were sitting in the shade eating lunch, we were trying to figure out the best way back to meet up with the main trail. Off in the near distance I spotted a ridgeline that looked interesting. Unfortunately it got tight not too far in. I hiked on ahead once I got through the squeeze with a bit of body modification. That is when I realized the trail was not going to work. It pinched off and then disappeared for the most part. This is where we turned around.
Kristal was piloting the Jeep as Chris was spotting Nick through the trail.
Here is me coming back through the spot that I failed on going through by braille. Chris spotted me through coming up and saved me from further issue.
The veiw from up here was epic though.
Unfortunately, Nick's trucks steering was not happy with the extra stress and strain the rocks put on it. While trying to get him turned around the power steering rack started crying red tears. We got it cooled off and topped back off, but we soon would learn that it was terminal.
To be continued...
Aygo
Love the truck. Wish my mega looked like this. It'd be pointless with 2WD though. I'll just have to live vicariously through you lol.
