SOLD 2014 Nissan NV3500HD SV high roof with Quigley 4x4
KMG
2014 Nissan NV 3500HD
High Roof SV Model
19,XXX Miles
$32,000
I've added:
Hehr brand awning screened windows.
400Ah battery system with CTEK with Smartpass solar controller connected to a roof mounted 135W panel.
Treadplate aluminum lower wall panels with tie down tracks.
RB Components brand folding dinette/bed.
Lighting and two fans.
Goodyear 265/75/17 DuraTracs since new.
Located in Springfield, MO
Thanks, Kevin
KMG
5.6 V8. FYI, The 3500 isn't available with the V6. Tow 9,000lbs. or Haul 4,000lbs.
CuStOm
Do you have additional pictures you could email? I don't see the solar or fans in those pictures.
kereams at yahoo
KMG
kereams at yahoo
Dinette Setup
Blue Sea Switch Panel with circuit breakers. Switches control the following:
Fan over sliding door. Cools Bed/Dinette.
Two gooseneck lights. One for reading in bed and the other lights the table when setup as dinette.
Two color dome light. Select either red or white LEDs.
Solar Panel.
Watertight solar panel plug. Allows for easy panel removal.
Accessory Panel. circuit breaker on/off switch separate from main panel. One accessory plug and two USB.
KMG
Fantastic fan. Pulls air in from other screened windows and exhausts out screened awning window. Fan control at master switch panel.
Sorry, I don't know why my pictures change orientation. Thanks, Kevin
KMG
That would be a killer weekend moto rig for races.
I built it so every "camping" item can be removed for work or folded up to carry a toy to the campsite then lower the shelving and bed/dinette.
KMG
I also have a Motorhome that my wife prefers. She won't "camp" but will RV. I'm going to build a FJ40 to trailer and use after I get to my destination.
KMG
I'd be interested in a partial trade for a restored Toyota FJ40 or a 2007 or newer Jeep. Thanks
cruiserfanc
looks like it was a passenger version or was it a cargo and you added the windows?
any pics of the cab area and battery/solar/controller setup?
ballpark interior height?
I've had the NV3500 on my short list for an offroad campervan build for quite some time due to the impressive specs and it looks like you've done a great job with setting up the beginning of what could be an excellent offroad alternative to a costly sprinter build. Ive got a '95 FJ80 that needs sold so the timing may not be right, but it looks great....GLWS!
KMG
The high roof models only come as a cargo van with an option for a fixed sliding door window and fixed rear door windows with defrosters. I purchased the van new with out the sliding door window but with the rear. I had HEHR brand awning style windows with screens installed on both sides and the sliding door. I'll post pictures of the cab area tomorrow. Below are images of the solar system. Nissan spec shows 76.9" inside cargo height. I'm 6'2" and clear with a cap on.
CTEK 250Dual with Smartpass solar controller. 40amp main disconnect / circuit breaker. Battery bank harness receptacle.
Solar system, Fantastic fan vents out the rear screened awning window, white hatch allows access to factory inverter.
Removable battery bank with 4 100Ah AGM batteries wired in parallel, 800W inverter, toggle switch controlled led light to aid in seeing solar system at night, round louvered vent on each end. End shown has small vent fan inside battery box to aid in cooling while charging.
Inside of removable battery box.
KMG
Here are the images of the cab area.
gp01
