Ram Power Wagon/Turtleback Trailer Expedition/Overlanding Rig For Sale - $89,500
*** Expedition/Overlanding Rig For Sale: ***
My wife has decided to start her own business, so in an effort to support her entrepreneurial spirit I've decided to sell my Expedition/Overlanding Rig to help her fund the endeavor. This setup comes fully equipped and will be turn-key ready for any adventure.
Please PM me with any questions you might have. Serious inquiries only please. Thank you.
The specifications for this expedition rig are as follows:
2013 Ram 2500 Power Wagon (Tradesman)
• Setup: Crew-Cab - 4X4 - 6’4” Bed
• Exterior Color: Bright White
• Interior Color: Black / Diesel Gray
• Interior: Cloth 40/20/40 Bench Seat
• Engine: 5.7-Liter V8 HEMI VVT
• Transmission: 6-Speed Automatic
Standard Equipment:
General:
• Advanced Multistage Front Airbags
• Supplemental Side-Curtain Front and Rear Airbags
• Supplemental Front Seat-Mounted Side Airbags
• Manual Shift-On-The-Fly Transfer Case
• TPMS Pressure Display
• Electronic Stability Control
• Heavy Duty Engine Cooling
• Transmission Oil Cooler
• Anti-Lock 4-Wheel Disk Brakes
• 730 Amp Battery
• Sentry Key Theft Deterrent System
• Cruise Control
• Power Door Locks
• Power Front Windows w/ 1-Touch Up and Down Feature
• Halogen Quad Headlamps
• Incandescent Tail Lamps
• Tip Start
Interior Features:
• Air Conditioning
• 6 Speakers
• Media Hub (USB, Aux.)
• Instrument Cluster with Display Screen
• 40 / 20 / 40 Split Bench Seat
• Front Armrest w/ Cup Holders
• Mini Floor Console
• Rear Folding Seat
• Second-Row In-Floor Storage Bins
• Rear Under-Seat Storage Compartments
• 12V Aux Power Outlet
• Tilt Steering Column
• Power Accessory Delay
Exterior Features:
• Locking Tailgate
• Class V Receiver Hitch
• 7-Pin Wiring Harness
• Trailer Tow w/ 4-Pin Connector Wiring
Optional Equipment: Customer Preferred Package 26B
• 17-Inch x 8.0-Inch Alcoa Aluminum Wheels w/ Internal Beadlock
• 180 Amp Alternator
• 4.56 Axle Ratios
• Black Headlamp Filler Panel
• Black Wheel Flares
• Fog Lamps
• Front Disconnecting Stabilizer Bar
• Warn M15000 Electric Winch
• Fuel Tank Skid Plate Shield
• Power Wagon Off-Road Group
• Transfer Case Skid Plate Shield
• Tru-Lok Front and Rear Axle Lockers
• Remote Keyless Entry
• Power Heated T-Tow Mirrors w/ Puddle & Signal Lamps
• Clear Lens Clearance Lamps
• Uconnect 5.0 AM/FM/BT
o Integrated Voice Command w/ Bluetooth
o SiriusXM Sattelite Radio
• Remote USB Port
• Overhead Console
• Rearview Mirror w/ Microphone
• Zak Tek Paint Protection
• 5-Year/100,000-Mile Powertrain Limited Warranty
Customization:
• Suspension
o Carli 3" 2.5 Pintop Suspension w/ Carli Low-Mount Steering Stabilizer
• Rims
o Powder Coated Flat-Black by Vyne Powder Coat
• Tires
o Goodyear Wrangler MT/R w/ Kevlar 37x12.5 17
• Body
o Softtopper Bed Topper
o White Knuckle Rock Rails (Powder Coated to Match Rims)
o TrailReady Pre-Runner Guard Front Bumper (Powder Coated to Match Rims)
o Warn 5742 Roller Fairlead
o Trailready Rear Bumper (Powder Coated to Match Rims)
o Four(4) Smittybilt 5/8" D-Ring Shackles
o Inyati Bed-Lined Bed and Rocker Panels
o DeeZee Rubber Bed Mat
o OEM Power Wagon Decals
• Lighting
o PIAA 540 Xtreme Driving Lamps
o PIAA 530 LED Fog Lamps
o PIAA 534 Back-Up Lights
• Interior
o Covercraft (Carhartt) Seat Covers (Full Set)
o Weathertech Floor Liners (Full Set)
o Covercraft UVS Heatshield Windshield Shade
o ARB Fridge Remote Wireless Display
o Tinted Windows
• Performance
o Diablo DCX inTune I-1000 w/ Hemifever Tuning
o Corsa 3" Performance Cat-Back Exhaust
o AEV Ram Snorkel (Raised Air Intake System)
• Recovery
o Stihl MS211 Chainsaw
o Blackjack KT-340 Tire Repair Tool
o Two(2) Warn Winch Dampers
o Hi-Lift Jack ORB Off-Road Base
o ARB ARB505 E-Z Deflator
o Smittybilt 2748 Snatch Block - 36,000 lbs. Rating
o Rugged Ridge 3" X 6' Tree Trunk Protector - 36,000lb Capacity
o Rugged Ridge Recovery 3" x 30' Strap - 30,000lb Capacity
o ARB 12V High Performance Portable Air Compressor
o Fiberglass Axe & Hatchet Set
• Towing
o OEM Back Up Camera
o OEM Trailer Brake Controller
o Class V Hitch Ball, Ball Mount, & Pin
o Class III Hitch Ball, Ball Mount, & Pin
• Misc.
o Custom Dealer Programming
2016 Turtleback 1A 4x6 Expedition Camp Trailer
Standard Equipment:
Chassis/Suspension:
• Full Steel Trailer w/ 2”x3” Perimeter Box Frame
o Forward & Aft Receiver Hitches on Frame
o Inyati Bedliner Coated Chassis
• 3,500lb Stub Rubber Torsion Axles w/ 2,750lb Springs
• 10” Electric Brakes
• 2,000lb Swing-Away Tongue Jack w/ Foot
• Safety Chains
• UCF Spare Spindle/Trailing Arm
Body:
• 0.050” White Aluminum Skin
• Two Side Compartments, One Front Compartment, & One Rear Compartment
o Doors w/ Matching Keys to Each
• Storage Box Set:
o 48”x32” Nose Box
o 45” Side Box
o 25” Side Box
• 4-Rail Cargo Bar Roof Rack
Electrical:
• LED Lighting Throughout
• Deka Group 24 AGM Marine Battery in Box w/ Blue Sea Fused Terminal Block
• Blue Sea Systems Marine Grade Electrical Components
• 7-Way Flat Trailer Plug (wired to):
o Running Lights, Brake Lights, Turn Signals, Charge Line, Trailer Brakes, & Interior Lighting
Kitchen/Shower:
• 42 Gallon Fresh Water Tank
o Food Grade
o BPA Free Construction
• 20lb Propane Tank w/ Stainless Steel Bracket
• Flowjet 12V Demand Water Pump
• Atwood 6-Gallon DSI Water Heater
• Exterior Marine Shower
• Baltic Birch Pantry Drawer
• Baltic Birch Slide-Out Kitchen w/ Two Drawers
• Wedgewood Two-Burner Stainless Steel Stove w/ Stainless Cover
• Atwood Stainless Steel Sink w/ H&C Faucet
Tailgate:
• 18”x36” Brushed Stainless Steel Fold-Down Table
• Spare Tire Mount
• Spare Idler Hub w/ Greased Bearings
• Turtleback Trailers Roto-Pax Dual Mounts (2)
Upgrades:
Chassis/Suspension:
• 4” Lift for 37” Tires
• 5-Lug-to-8-Lug Wheel Adapters (3)
• Max Coupler Hitch (6,000lb Rating)
• Rims:
o OEM Ram Power Wagon Wheels (3)
• Powder Coated Flat Black by Vyne Powdercoating
• OEM Wheel Nuts (24)
• OEM Hub Caps (3)
o OEM RAM HD Steel Spare Wheels (2)
• Tires:
o Goodyear Wrangler MT/R w/ Kevlar 37x12.5 17 (3)
o Yokohama S Drive 205/40 R17 (2)
Body:
• Storage:
o 4" Tube Storage System (Foxwing Awning Accessories)
o Turtleback Trailers Front Cabinet Divider
o Turtleback Trailers Door Latches (2)
• Leveling:
o Turtleback Trailers Jack Posts (4)
o 2,000lb Pro Series Stabilizer Jacks (4)
o Rubber Wheel Chocks (4)
• Accessories:
o Picnic Table Mount – Double
o Spare Grill Tank w/ Stainless Steel Bracket
Electrical:
• 2nd Battery – Deka 8A24M
o Deka AGM 79 Amp Battery, Battery Box, Blue Sea Fused Terminal Block
• Electrical System Upgrade – Dual Battery System
o Blue Sea Battery Disconnect, Blue Sea 6-Circuit Fuse Block, 6 Amp Marine Battery Charger (Shore Power), & 10 Amp Solar Controller w/ Voltage Meter
• Pure Sine Wave Inverter Package
o Blue Sea Battery Disconnect, Blue Sea 150 Amp Breaker, & 2,000 Watt Xantrex Pure Wave Inverter
• Additional Charging Port
o Blue Sea Marine USB Dual Port, Blue Sea Marine Kela Plug, & Stainless Steel Backing Plate
• Overland Solar 90 Watt Collapsible Panel
Kitchen/Shower
• ARB 82qt Refridgerator
o ARB 82qt Cover
o ARB Refridgerator Strap Kit
• Magma Nestable 10-Piece Stainless Steel Cook Set w/ Ceramic Non-Stick Liner
• Oster Compact Toaster Oven
• Lifetime Products 72”x30” Folding Tables (2)
• Utensil Set
• Ladel & Spatula Set
• Cutlery Set
• Cutting Sheets
• Oven Mitt & Pad Set
Awning:
• Foxwing Awning
o Stainless Awning Bracket – Pair
• Foxwing Awning Tapered Extension Panels (2)
Roof Top Tent:
• Cascadia Vehicle Tents CVT Mt. Rainier Stargazer RTT w/ Extension & Rainfly
o Spare Extension
Tent/Bed:
• 4" Memory Foam Mattress
• Mr. Heater Big Buddy Heater
o 20lb Propane Tank
o 15ft Propane Gas Line
• Assorted Rubber Mats
Recovery:
• Hi-Lift Extreme 60” Jack
• Roto-Pax 4-Gallon Fuel Cans (2)
o Roto-Pax DLX Pack Mounts (2)
o Roto-Pax Double Mount (2)
Hygiene:
• Luggable Loo 5-Gallon Toilet
• Collapsible 30-Gallon Garbage Can
• Compact Dust Pan & Broom
• Ozark Trail Instant 2-Room Shower Tent
o Shower Hose Extension
Lighting:
• Streamlight Siege LED Lanterns (3)
• Utilitech 24ft Rope Light
• Assorted Extension Cords
Miscellaneous:
• Assorted Other Tools & Supplies
• Portable Horseshoe Set
Truck: Just hit 38,000 miles. It has always been serviced at the dealership. Fluid changes have always included Royal Purple products. All records have been saved and will be included with sale.
Trailer: Less than 8,000 miles. Less than a year old. Several enhancing modifications. All records have been saved and will be included with sale.
zhukoveli
