M101 cdn build
08_jku
Just picked up a very solid M101 CDN to start my build.
Trailer as bought:
Spring over conversion
35" tires
Tongue mounted water tank
Short term build:
Aluminum lid
RTT (already aquired)
Awning (already aquired)
Fabrication of raising and lower awning
Gravity fed water mounted in trailers box (14 gal tank came with trailer)
Stabilizer jacks
12v power system in tongue box
Long term build:
water pump
Water tank mounted underneath
Spare tire carrier (35" tire)
No idea how to add pictures........
08_jku
Yes I have made a bit of progress on the build have been very busy and have not taken much picture unfortunately
Trailer when I purchased
Fabricating brackets to raise and lower awning
Extended hitch tube installed
Aluminum Lid with 150lb gas struts and RTT installed
Awning installed yesterday
I have a maiden voyage planned for this weekend even though there is a lot more to do the trailer is campable and this will help me work out any kinks and gauge needs for future modification.
AML
Nice. You work fast. I have a similar trailer but am not working the same speed you are. Hopefully I get my act together soon and start a build thread soon. Looking forward to your progress.
harv3589
When u did the axle flip did u keep the hand brake? Just wondering if the cables were to short? Thinking of doing that to mine. Also any difference in how it rides?
08_jku
Thanks.....I had a deadline for a camping trip which kept me gear......since the I have not made much progress need to jump back in it. Good luck with your build
08_jku
I bought already flipped and the hand brake was already removed as well.
DanoWall
