Zen Overland Build
ZEN ADV
2016 CM 5.7l 4x4 SR 5.
This is my 3rd Tundra after a 2001 and 2006. I wanted an SR with a center console and no other extras as I would add my own mods. I didn't want any wood or chrome to mess with inside or out so this model was what I ordered and I picked it up at the end of July. Work started the next day. I'm just now at 4,000 miles on the truck.
CURRENT BUILD & MODS
-Katskin leather interior, dealer installed.
-Pro Grille
-ARE HD Shell, fully LineX coated
-Rhino Racks
-OME 613 kit with Dakar leaf pack plus (2) D28XL added leafs per side.
-Method NV 18x9
-Toyo Opencountry RT 35x12.5
-Full size matching spare under truck
-Bushwacker Extend-a-Flares
-Expedition One Front and Rear Bumpers
-White Knuckle .188 DOM Sliders
Bedliner Coated in Garage. Easy to touch up
-PIAA 540 Xtreme White Top Mounted 5" Driving Lamps
-PIAA 5161 Plasma Ion Yellow Fog Lamps in Front Bumper
-PIAA LP 530 Flood Backup Lamps
-Superwinch Talon 12.5SR with synthetic rope and Factor55 FlatLink Shackle Mount. Winch Plug mounted in Grille with trailer wire connector for grille removal when needed.
-ARB Shackles, Recovery Straps, Tree Strap, Snatch Block, Strap Damper, etc.
-Custom 1/4" Plate Steel RAM Mount Base on Dash with Bedliner Finish. Holds Zumo GPS, Video camera, whatever.
-Blue Sea Fuse Block on Custom Tip up plate for battery access
-RAM X Grips screwed into dash surround. Holds Phones, SPOT, DeLorme, etc.
-Cargoglide 1,000 lb. rated bed slide
-Custom Built Wheel Well Storage with removable panels for dog platform. Fits Pelican cases and as needed, 2nd full size spare below.
-ARB CKMTA12 Dual Compressor On-Board Air. Hardwired into slide out case
-ARB Deflators (2, put the wife to work on her side)
25' Coxreels Air Hose, Permanently Connected in slide out case
-Antigravity XP-10 Power Supply and Jump
Skinhyfish
-Pro Grille
-Rhino Racks
-Method NV 18x9
How do you like the double add a leaf set up? I’ve only see it once. Have a set getting ready to go in, but kind of want to add another set while I’m tearing apart? Ride looks good, but did it feel to high at all?
