custom 8x6 popup camper for flat bed truck or trailer
mikerwc
Hello folks! I was aimed at this cool cite in regards to my attempt at selling my custom pop up camper, my reson for selling is i plan to build a pull behind camper to replace it. I am in Montana heading to California had the camper in Alaska all year.
This lill camper is around 40" tall but raises up to around 80" allowing one to walk (I am 6'1") around inside without ducking.
Bench folds out into a twin bed, lots of storage room, one small solar charged lamp there is no electricity or water plumed otherwise altho I have a solar system to install in it and plan to do so before a sale. to pop the camper up there is a crank that is turned. this camper is compact and sturdy.
Iv used a small generator to run a 1500 watt heater in 10-20F degrees and it gets hotter than one cares, all the walls roof and floor are insulated with one inch foam with the shiny reflective stuff on it (Milar?)
this measures approximately 6 foot wide by 8 foot long and 4 foot tall.its construction is of steal and aluminum frame with an aluminum skin and Id estimate its weight at around 1000lbs
I can install this camper on a trailer frame at a small charge. if interested please contact.
831 two 61 61zero8
ripperj
That's pretty cool, does the top telescope up in three sections? How are they sealed?
Good luck with the sale
Sent from my Passport
mikerwc
Yes there are three walls that telescope up. The outer shell, inner floating wall and base wall. Basic neoprene rubber gaskets seal it.
FAMILY_OF_SIX
Explorers
Welcome to the Portal. Great to see a custom job.
You'll find the majority of us on here are "Makers" and appreciate seeing ingenuity and hard work.
Good luck with your sale.
A&P
oskarf150
