Two days late.....Two dollars short
FDM2012
You know, there's more than one guy floating around here with a 3D printer, probably just looking for an excuse to use it. Maybe someone could whip you up some wedge shaped inserts to go between the lights and the ambo to get the angle you're after.
That would be AWESOME!
I could order another one, and have it sent to you. I would want/need 6 of them. And I reckon at the same angle
as what your are on your rig. I'm guessing they are just about right.
tgreening
Haha! Dude, right idea but wrong conclusion. When I said "more than one guy" I meant it, but I don't remember who they are and they for sure aren't me. :)
FDM2012
Lol DANG IT!!
No worries, I will put my IMPROV skills to work on it.
lockedwheels
My photobucket app is all jacked up it won't let me share photos. I deleted the large red lights on the back and mounted my back up camera. Maybe pick to follow
Sent from my SM-G930T using Tapatalk
lockedwheels
Bikersmurf
Looks good... I'd almost move the lights out to the corners of the roof for better light distribution. That said, mine are still in the same place.
I've also contemplated wiring the 'Red' lights into the turn signal circuits... just not sure on the legality of doing it.
lockedwheels
Yah know that's a good idea. I had planned on using two small flood light bars one pointed down and one pointed more outward. Having two small pods on the corners would sure cover a lot of area. I am just glad to get rid of the gigantic red lights.
lockedwheels
So I installed the rear view camera and mounted it where the PA system was
While I was doing that I was looking at the wiring
Started removing obsolete stuff
When I have been camping I keep the batteries turned off because I keep the doors open which turns the side/rear floods on. Well that's a great but then I didn't have interior lights. So I removed the pressure switches on the doors and installed a switch for the side doors and a switch for the back doors. Now I can keep the batteries switched on and if I want to turn on the floods I can switch them on. The main switches above the driver are still active as well so I can turn them on from the drivers seat too.
lockedwheels
Got the fuel bowl out.
I found this in the valley when I got the fuel bowl out. Anyone have any ideas what it's for?
As I was tearing apart the fuel bowl the fuel bowl heater just fell apart. I got aggravated and quit. Haha $60 later and the new heater is on order. I will finish disassembling it and cleaning it tomorow. Maybe get part of it back together while waiting on parts.
PNWav
