DaveInDenver
Middle Income Semi-Redneck
Nothing lasts forever. The problem with buying used is that there's a previous owner who did who knows what. But I'd trust a Toyota to 250K with reasonable car and 100K really is relatively low miles.
I'm not young either Clutch and remember when 100K really did mean your car was done. Volvo, Honda and Toyota primarily changed that in the 1970s and 1980s and necessitated adding a 6th digit to odometers. There was a time when 100K would be an instant walk, you know like on a Duster, Chevelle or Pinto.
I'd personally look at any Toyota with under 200K and judge solely on the individual vehicle's merit. Some are exceptional, some so-so. Thing is even a badly abused 200K Tacoma is usually still running.
Having had a few old Toyotas now I think the main difference is that they usually don't fail without warning. My 22R-E blew its timing chain at 175K but that wasn't the engine's fault totally. I swapped from the stock nylon guides to metal-backed aftermarket (D.O.A. Racing Engines) with no real reason (they hadn't failed) other than preventative.
I did not use OEM or equivalent OSK parts but rather the domestic crap supplied in the kit. The chain tensioner had failed and in retrospect I should have realized that it was telling me for about 3 months. But I thought /for sure/ that the noise was just valvetrain chatter, it simply could not be the timing chain since I had just done it. Wrong. When I took it apart the tensioner had failed and the metal back guides took the slack for while, apparently flexing at the top of the driver's (long) side until it eventually fatigued and snapped off. It wrapped around in the chain and lodged around the crankshaft gear, snapping the chain.
It decided to do this about 1/4 mile from home and the starter drove me home the couple of blocks to the garage. Didn't need a tow truck even.
